I got my Photon in the mail, I plugged it in, joined it to my Wifi, and while it was automatically being flashed with the initial software, I unplugged my Photon (silly I know…)
Now it basically doesn’t do anything other than a White RGB LED and a dim D7 LED. I tried factory reset but no luck.
I can get into DFU mode. I was wondering if there are pre-built images I can flash instead of building them myself. If they exist, can someone point them to me.
I followed the instructions and now the Photon instantly goes into this state (D7 ON), (RGB barely lit).
I can still get into DFU. I think it might be current firmware/tinker app. The instructions state:
An additional optional step is resetting the current firmware and factory backup to tinker. This is done by flashing
user-part.bin to 0x80A0000
user-part.bin to 0x80E0000 (factory reset location)
However, I dont see the user-part.bin to download. I only see these:
Flashed an app compiled by the CLI (latest) but once the Photon reboots it goes back into that same state as before.
Might be a silly question, but how do I compile for the Photon? Are the Core/Photon User Code compatible or do you have to compile specifically for the Photon?
Very strange. Unplugging the photon during the initial OTA shouldn’t brick it, unless you did it just at the moment when it has reset after the data has been downloaded.
Once you have flashed system_pad.bin (or equivalently system part1 and part2 - system_pad is simply part1 and part2 concatenated) then perform a firmware reset. This will copy tinker from the factory backup location.
Invalid DFU suffix signature
Cannot open DFU device 2b04:d006
Opening DFU capable USB device…
ID 2b04:d006
Claiming USB DFU Interface…
Setting Alternate Setting #0 …
dfuIDLE, continuing
Downloading to address = 0x08020000, size = 393216
Download [=========================] 100% 393216 bytes
Download done.
File downloaded successfully
Error during download get_status
Same thing. I went and redownloaded the file, reflashed. Then tried to do a Factory Reset (hold setup, tap reset, wait till flashing green then release setup).
ID 2b04:d006
dfuIDLE, continuing
Download done.
I hate to continue bringing this up… but I got this happening.
I hold SETUP, tap RESET, and then if I release SETUP maybe 1-3 seconds while its flashing magenta, then the RGB led turns a solid blue. D7 is still on as well.
Not sure if releavent, but a solid BLUE RGB means “Transferring WiFi Info”? I wonder if something went wrong there.
I am sorry I don’t have much more to contribute on your actual problem–perhaps @mdma has more ideas!
But your picture shows a less-than-good practice: You should remove the Photon from the black conductive foam that is used to prevent static problems during shipping and handling when you power up the device. It is like you have a connected a bunch of resistors between all the pins of the device. I don’t think this causing your problems but it is not a good idea and you should remove it.
