Particle Workbench Support for Monolithic Builds (Mesh)
Hi everyone,
I am new to the particle environment, and I’ve read some forum posts that state Particle Workbench supports monolithic builds (https://community.particle.io/t/local-compilation-questions-for-mesh-devices/47061; Mesh range testing).
I can’t seem to find where to specify that I do not want a modular build. Can someone direct me to where I should be looking?
Thanks.
From the command palette, “Particle: Compile application for debug (local)” builds a monolithic build.
Awesome. thank you!
I was able to replicate your mesh range testing project.
Thanks for the help!
