Particle Workbench Local Flash error
Just came to do a Local Flash from the Particle Workbench and this
Device in DFU mode (flashing yellow) and connected to USB - start local flash and it fails thus:
particle: Installing plugins... done
ERROR: runtime error: invalid memory address or nil pointer dereference
make: *** [/Users/wxy/Documents/Intelligent_Furniture_Project/VSC_Projects/xxx-xxx-base/src/xxx-xxx-base.cpp] Error 1
 *  The terminal process "/bin/bash '-c', 'make -f '/Users/wxy/.particle/toolchains/buildscripts/1.10.0/Makefile' flash-all -s'" terminated with exit code: 2.
 *  Press any key to close the terminal.
V1.16.1/restarted VSC. Any ideas?
[Update] The solution is here: CLI updated to Node 16
Thanks to Juffin
