Particle Workbench Installation Failure for Windows Platform
I’m trying to install the Particle Workbench and the installation fails after the Windows code installs. Please the error below:
Windows 10
TypeError [ERR_INVALID_ARG_TYPE]: The “path” argument must be of type string. Received type undefined
The problem has been fixed. MS Visual code installed on a different drive (ie f:) instead of the C drive which the installer I guess didn’t like! I had to uninstall VSC to get it to install under the C drive. This Issue needs to get fixed! You should have the ability to install these packages to any local drive…
