We’re trying to create our first Webhook that’ll send data to a CHORDS system. We found some info at https://earthcubeprojects-chords.github.io/chords-docs/usingchords/#particle-iot-hardwarehttps://earthcubeprojects-chords.github.io/chords-docs/usingchords/#particle-iot-hardware but we’re having an issue.
If we hard-code the values, it sends them, but if we have it use variables, the HTTP Request doesn’t include the values. As an example, here’s what we have right now (minus the potentially sensitive data…
GET /measurements/url_create?atmospheric_pressure=810.8&soil_moisture_content=76&soil_temperature=10.4&atmospheric_humidity=37&battery_voltage=3.7&***atmospheric_temperature=***&api_key=<api_key>&email=&instrument_id=1 HTTP/1.1 User-Agent: ParticleBot/1.1 (https://docs.particle.io/webhooks) host: Connection: keep-alive
As you might be able to guess, all values except for apmospheric_temperature are hard-coded.
We know for sure the instrument is working because in the events, we can see it fire (we have it fire every minute at least for now) and the value shows up. However, the actual value isn’t sent.
Any ideas?
Dennis
