8/11/2017: Console: Ping a device
See if your device is online by pinging it. Available on the device show page (click on any device from the devices table). This should be useful especially for Electrons.
Happy pinging!
Happy pinging!
Aug 15th 2017: Firmware v0.7.0-rc.3
A new pre-release firmware v0.7.0-rc.3 is available now on https://build.particle.io for Core/Photon/P1/Electron.
The changelog is short, so here it is!
[PR #1365] Beginning with 0.8.0 release, Particle.publish() and Particle.subscribe() methods will require event scope to be specified explicitly. Please update your apps now to include the event scope to avoid compilation errors in >=0.8.0.
[PR #1362] [Fixes #1360] Fixed SoftAP HTTP usage hard faulting in 0.7.0-rc.1 and 0.7.0-rc.2
Be sure to read the full collection of notes in the changelog.
We want 0.7.0 to be rock solid and as bug-free as possible so please let us know if you find any issues.
Aug 29th 2017: particle device doctor
The CLI release 1.24.0 adds a new device doctor command that resets many settings on a device to bring it back to health.
Update the CLI with npm install -g particle-cli
Run particle device doctor with a device connected over USB and follow the prompts.
The CLI documentation lists all the settings that the Doctor resets.
A
a day keeps the Device Doctor away!
Firmware Release 0.5.5
Hey everyone! 0.5.5 firmware is released. The primary change is a patch for the KRACK Wi-Fi vulnerability. Particle Firmware Updates Thread
Firmware Release 0.6.3
Hey everyone! 0.6.3 firmware is released. The primary change is a patch for the KRACK Wi-Fi vulnerability. Particle Firmware Updates Thread
Console Webhook UI improvements
The webhook editor in the Console has a fresh coat of paint! See details in this forum thread.
January 8th 2018: Firmware Release 0.8.0-rc.1
January 16th 2018:
Web Setup for Photon now works on Safari and Edge browsers.
February 7th 2018: Firmware release 0.7.0-rc.7
March 23rd 2018:
Who likes surprise features right before the weekend? We do!
You can now download your Web IDE app sources as a ZIP file!
March 23rd 2018:
Rate limits on webhooks and integrations are no more!
March 26th 2018: Firmware v0.7.0
A new Default Release Firmware v0.7.0 is available now on https://build.particle.io for Core/Photon/P1/Electron.
Be sure to read the full collection of notes Particle Firmware Updates Thread.
April 10th 2018: Firmware v0.8.0-rc.3
A new pre-release firmware v0.8.0-rc.3 is available now on https://build.particle.io for Core/Photon/P1/Electron.
We want 0.8.0 to be rock
April 12th 2018:
You can now change your email (i.e., username) at https://login.particle.io/account-info.
May 4th 2018: Firmware v0.8.0-rc.4
A new pre-release firmware v0.8.0-rc.4 is available now on https://build.particle.io for Core/Photon/P1/Electron.
Particle.keepAlive() API was broken since v0.6.2-rc.2 firmware on Electron where the System would override an early set User ping interval. This required a workaround of updating the keepAlive after the System made a connection to the Cloud. See issue #1482 for workaround. #1536
May 29th 2018:
Changes to the behavior of Device OS updates for cellular devices are described in this post:
June 26th 2018: Firmware v0.8.0-rc.8
A new pre-release firmware v0.8.0-rc.8 is available now on https://build.particle.io for Core/Photon/P1/Electron.
Note: This is primarily a MFG. release for SARA-R410 LTE modules. The changes do touch code used on other Electron based platforms, but no other features or fixes are relevant for U260, U270, U201, or G350 modems. This code has been tested on-device for all mentioned modem types with passing results. Please let us know if you find any issues. That said, this is a release candidate for 0.8.0 default so please do test on your systems.
July 30th 2018: Firmware v0.8.0-rc.9
A new pre-release firmware v0.8.0-rc.9 is available now on https://build.particle.io for Core/Photon/P1/Electron.
Note: This is a release candidate for 0.8.0 default so please do test on your systems.
August 17th 2018: Firmware v0.8.0-rc.10
A new pre-release firmware v0.8.0-rc.10 is available now on https://build.particle.io for Core/Photon/P1/Electron.
