2/7/2017: Particle CLI 1.19.4
Features
#338 -
particle keys protocol
displays the currently configured protocol for the connected device -
#205 -
webhook delete all
command. Thanks @kennethlimcp! -
#240 -
particle serial monitor --follow
reconnects to the serial port when the device resets. Thanks @derekmpeterson! -
#225 - ability to specify a
.json
file to enter wifi credentials. Thanks @markterrill! -
--no-update-check
to skip checks for updated versions
Fixes
#326 - unhandled rejection in
help
#235 - Unhandled error in
particle setup
- #331 - Flashing a known app causes exception
- #328 - ParticleCLISetup for Windows broken due to OpenSSL download problem
- #326 - Unhandled rejection in help
- #321 - keys doctor (device id) is case sensitive
- #292 - this -> self
- #280 - Incorrect key pulled for Electron using TCP
- #279 - Server key address output incorrect for Electron using TCP
- #231 - max retry for wifi scan error
- #299 - update glob dependency to avoid warning about minimatch vulnerability. Thanks @snyk-bot.
