Any feedback is appreciated!
I’m still pretty new at creating tutorials, but the goal is to be helpful above all.
The video is great.
I learn best and quickest by watching tutorials like this. If only there was a tutorial for every function of the Photon, that would be ideal.
Your doing a great job and I think many people will get good use and save alot of time by watching them.
Keep them coming
Nice!
One thing you should incorporate in your code is some kind of rate limiting to obay the 1 publish per second rule.
Thank you, I totally forgot about that! I’ll address that in another video when I write more complex code
Here’s a link to yet another video, explaining the Particle.variable() method.
Nice again
Just some notes:
Although the docs haven’t been updated yet, you can already use different datatypes for Particle.variables()
than the three mentioned.
And your initialization of int photoResistorReading = A0;
is a bit unorthodox, since you first use that var as pin denominator and later on just reuse it for the value while hard coding A0
Scruff, I’m obviously having a meltdown haha. I’ve decided to leave it as is. In the end it’s what worked for me and I tried remaking the videos to no avail, they just weren’t coming out as well
Here’s another
