We have about 10 devices connected to local node.js instance. We are observing that after we do firmware upgrade or restart the local node.js server while the devices are running, some of the particle photon devices go into a breathing white mode and the application firmware is not running (as we do not see it online on the node.js side).However, after resetting the device, the devices run normally.
Does anyone know why this happens? What is this mode and what does it signify? I cannot find much info about this state of the device.
TIA
icon
