If I want to switch from using the Photon 2 to the P2 for final production, has there been a mounting socket developed for the P2 or does it have to be directly soldered onto the PCB?
The P2 is intended to be SMT soldered to the PCB
That will probably be above my capacity to solder. A pinned socket would be nice and easy to solder to a PCB, but the P2 looks a little difficult.
