Particle MP3 sound playing
Hello guys, i am looking to add an mp3 that plays certain sounds. i am currently looking at this hardware but it is built for arduino. Do you think this would work on particle firmware? if not… what is the best way to add an mp3 that plays recorded sounds on a particle device.
This is the hardware i am looking at:
-https://www.seeedstudio.com/Grove-MP3-V3-p-4297.html
-https://www.seeedstudio.com/Mono-Enclosed-Speaker-2W-6-Ohm-p-2832.html
Don't know about the best, but this is definetly one of the cheaper and proven to work
However, the Grove module also uses a UART interface to communicate it will also work with Particle devices.
But the docs provided on the SeeedStudio site are not too useful unless you can read Chinese :wink:
Okay Thanks again ScruffR. Also, what rgb light strips would work that are 3.3v to work with the grove shield? because most of the strips are higher than 3.3v
