Particle Mesh Ethernet FeatherWing support
Yes, any Particle Mesh device will be able to use the Ethernet FeatherWing to connect to the Device Cloud. So an Argon or Boron can use the Ethernet interface instead of Wi-Fi and Cellular. That also means a Xenon can be used as an Ethernet Gateway for a local mesh.
