Hi Particle Support!
This ParticleFunction() cannot be Called from the Web-Console (https://console.particle.io/…)
Particle.function(“Send debug Infos 0/1”, SetTxDebug);
This works as normally
Particle.function(“Send debug Infos 0 or 1”, SetTxDebug);
I worked on a B523 and use Firmware V5.2.0…
All the best and have a nice day…
Andreas
There is a note about the naming convention of functions
So, not a bug but by design.
Not only the forward slash but also spaces should be avoided.
Greetings from Salzburg (by another Andreas
Hi ScruffR, tanks a lot for clarification! Sorry to bother you by my mistake…
Note: Only use letters, numbers, underscores and dashes in function names.
Have a nice day!
Andreas
Greetings from Miesenbach, NÖ
