I am using a kalman filter and when i run this software, my electron flashes red.
Please take a look at the code below at the link:
Can you be more specific about the red flashing error?
https://docs.particle.io/guide/getting-started/modes/photon/#red-flash-sos
There are a number of other red blink codes that may be expressed after the SOS blinks:
Hard fault Non-maskable interrupt fault Memory Manager fault Bus fault Usage fault Invalid length Exit Out of heap memory SPI over-run Assertion failure Invalid case Pure virtual call Stack overflow
The code that i have provided at the link successfully flashes but the electron blinks red after the code is flashed. I put the electron in safe mode and ran another source code that I had working earlier, that worked perfectly fine. It is only when i run this code, the flashing occurs. The library for the Kalman filter can be found on the web IDE, its under āKalmanā.
The question @HEng raised was: What kind of red flashing do you see?
Either you can provide a video or describe the flashing as best you can.
What colors do you see on the lead-up to the red flash?
Is it SOS (or not)?
What number of red flashes do you see between the SOS instances?
@HEng I have attached a video of the issue.
I would start here:
Apparently a divide-by-zero can cause this, among other things.
You should also have the LiPo connected in order to have the radio module supplied with enough peak current to not interfere with the µC.
Most common reason for a Usage Fault is a DIV/0 exception. Check your code for that condition - in your .ino file are several instances where the denominator can potentially become zero.
Another tip for the future is to add ābreak pointsā in your code to narrow down where in your code the exception happens.
e.g. via
Serial.println("breakpoint 1");
while(Serial.read() < 0) Particle.process(); // wait here till byte received via serial terminal
Serial.println("breakpoint 2");
Thank you both for replies. I will try to see through my code and reply back tomorrow. Thank you
