here is an update
i tried using the cellular helper debugging kit and here is the log
Seems like the 3rd party sim card is working, it connects to the internet successfully and then fails during the handshake. Knowing that this sim card used to work few days ago, and that the same electron works with the sim sent with the pack (so its not a keys issue) how do you believe i should proceed ?
0000010460 [app] INFO: attempting to connect to the cellular network…
0000020431 [system] INFO: Sim not inserted? Detecting…
0000021621 [system] INFO: Sim Ready
0000021621 [system] INFO: ARM_WLAN_WD 1
0000022461 [system] INFO: ARM_WLAN_WD 2
0000022461 [system] INFO: CLR_WLAN_WD 1, DHCP success
0000022461 [app] INFO: connected to the cellular network in 12001 milliseconds
0000022462 [app] INFO: running cellular tests
0000022513 [app] INFO: operator name=Orange EG
0000022563 [app] INFO: rssi=-51, qual=99, bars=5
0000023129 [app] INFO: service rat=GSM mcc=602, mnc=1, lac=b11f ci=fa78 band=GSM 900 rssi=0 bsic=d arfcn=59 rxlev=98
0000023130 [app] INFO: neighbor 0 rat=GSM mcc=602, mnc=1, lac=b11f ci=fa79 band=GSM 900 rssi=0 bsic=22 arfcn=56 rxlev=101
0000023131 [app] INFO: neighbor 2 rat=GSM mcc=602, mnc=1, lac=b11f ci=ffff band=GSM 900 rssi=-34 bsic=d arfcn=52 rxlev=87
0000023763 [app] INFO: lat=30.006256 lon=31.302370 alt=240 uncertainty=2306
0000023804 [app] INFO: ping 8.8.8.8=1
0000026296 [app] INFO: dns device.spark.io=107.22.156.56
0000026296 [app] INFO: cellular tests complete
0000026297 [app] INFO: press the MODE button to connect to the cloud
0000035379 [app] INFO: attempting to connect to the Particle cloud…
0000035461 [system] INFO: Cloud: connecting
0000035461 [system] INFO: Read Server Address = type:1,domain:$id.udp.particle.io
0000038462 [system] INFO: Resolved host 4c003d000b51343334363138.udp.particle.io to 54.86.250.117
0000038796 [system] INFO: Cloud socket connected
0000038796 [system] INFO: Starting handshake: presense_announce=0
0000038796 [comm.protocol.handshake] INFO: Establish secure connection
0000038820 [comm.dtls] INFO: (CMPL,RENEG,NO_SESS,ERR) restoreStatus=2
0000047978 [comm.dtls] ERROR: handshake failed -6800
0000047978 [comm.protocol.handshake] ERROR: handshake failed with code 17
0000047980 [system] WARN: Cloud handshake failed, code=17
0000048230 [system] INFO: Cloud: disconnecting
0000048270 [system] INFO: Cloud: disconnected
0000049020 [system] INFO: Cloud: connecting
0000049020 [system] INFO: Read Server Address = type:1,domain:$id.udp.particle.io
0000052303 [system] INFO: Resolved host 4c003d000b51343334363138.udp.particle.io to 54.158.45.132
0000052353 [system] INFO: Cloud socket connected
0000052353 [system] INFO: Starting handshake: presense_announce=0
0000052355 [comm.protocol.handshake] INFO: Establish secure connection
0000052377 [comm.dtls] INFO: (CMPL,RENEG,NO_SESS,ERR) restoreStatus=2
0000061535 [comm.dtls] ERROR: handshake failed -6800
0000061535 [comm.protocol.handshake] ERROR: handshake failed with code 17
0000061537 [system] WARN: Cloud handshake failed, code=17
0000061787 [system] INFO: Cloud: disconnecting
0000061827 [system] INFO: Cloud: disconnected
0000062627 [system] INFO: Cloud: connecting
0000062627 [system] INFO: Read Server Address = type:1,domain:$id.udp.particle.io
0000066310 [system] INFO: Resolved host 4c003d000b51343334363138.udp.particle.io to 34.207.118.100
0000066360 [system] INFO: Cloud socket connected
0000066360 [system] INFO: Starting handshake: presense_announce=0
0000066362 [comm.protocol.handshake] INFO: Establish secure connection
0000066384 [comm.dtls] INFO: (CMPL,RENEG,NO_SESS,ERR) restoreStatus=2
0000075542 [comm.dtls] ERROR: handshake failed -6800
0000075542 [comm.protocol.handshake] ERROR: handshake failed with code 17
0000075544 [system] WARN: Cloud handshake failed, code=17
0000075794 [system] INFO: Cloud: disconnecting
0000075834 [system] INFO: Cloud: disconnected
0000076634 [system] INFO: Cloud: connecting
0000076634 [system] INFO: Read Server Address = type:1,domain:$id.udp.particle.io
0000078627 [system] INFO: Resolved host 4c003d000b51343334363138.udp.particle.io to 34.207.118.100
0000078677 [system] INFO: Cloud socket connected
0000078677 [system] INFO: Starting handshake: presense_announce=0
0000078677 [comm.protocol.handshake] INFO: Establish secure connection
0000078701 [comm.dtls] INFO: (CMPL,RENEG,NO_SESS,ERR) restoreStatus=2
0000087859 [comm.dtls] ERROR: handshake failed -6800
0000087859 [comm.protocol.handshake] ERROR: handshake failed with code 17
0000087861 [system] WARN: Cloud handshake failed, code=17
0000088111 [system] INFO: Cloud: disconnecting
0000088151 [system] INFO: Cloud: disconnected
0000088951 [system] INFO: Cloud: connecting
0000088951 [system] INFO: Read Server Address = type:1,domain:$id.udp.particle.io
0000090544 [system] INFO: Resolved host 4c003d000b51343334363138.udp.particle.io to 184.72.215.47
0000090594 [system] INFO: Cloud socket connected
0000090594 [system] INFO: Starting handshake: presense_announce=0
0000090594 [comm.protocol.handshake] INFO: Establish secure connection
0000090618 [comm.dtls] INFO: (CMPL,RENEG,NO_SESS,ERR) restoreStatus=2
0000099776 [comm.dtls] ERROR: handshake failed -6800
0000099776 [comm.protocol.handshake] ERROR: handshake failed with code 17
0000099778 [system] WARN: Cloud handshake failed, code=17
0000100028 [system] INFO: Cloud: disconnecting
0000100068 [system] INFO: Cloud: disconnected
0000100868 [system] INFO: Cloud: connecting
0000100868 [system] INFO: Read Server Address = type:1,domain:$id.udp.particle.io
0000103521 [system] INFO: Resolved host 4c003d000b51343334363138.udp.particle.io to 54.164.79.148
0000103571 [system] INFO: Cloud socket connected
0000103571 [system] INFO: Starting handshake: presense_announce=0
0000103573 [comm.protocol.handshake] INFO: Establish secure connection
0000103595 [comm.dtls] INFO: (CMPL,RENEG,NO_SESS,ERR) restoreStatus=2
0000112753 [comm.dtls] ERROR: handshake failed -6800
0000112753 [comm.protocol.handshake] ERROR: handshake failed with code 17
0000112755 [system] WARN: Cloud handshake failed, code=17
0000113005 [system] INFO: Cloud: disconnecting
0000113045 [system] INFO: Cloud: disconnected
