Particle Electron Not Connecting
So my particle electron is breathing Cyan and the D7 led is blinking blue. So, when I flash it over usb it says it is successful and then it restarts and it cannot connect to the particle cloud but it is still breathing cyan and D7 is still blinking blue. Is there anything I can do to fix it? Thanks for the help.
Breathing cyan would mean it’s connected to the cloud, how do you know It’s not? Blinking blue D7 doesn’t normally happen unless you’ve told it to do so.
How exactly are you flashing the device? And could you try flashing known good code, like Tinker?
