I was taking the battery out of the particle electron and the red and black wires pulled out of the plastic component. While I was trying to insert them back in they touched each other and visually sparked. I am guessing I short circuited the battery because now when I plug it in the red flashing light turns off when it is supposed to be on. Is there anything I can do to fix this or am I just going to have to get a replacement?
I just tried it again right after I posted this, and the solid red LED turned back on. If I fool around with the cables eventually it recognizes the battery, but one simple movement can turn it off again. Eventually after around a minute it will turn off. How would I be able to order a replacement?
Hello @mpayne10,
Unfortunately we don’t sell replacement batteries at Particle, but Adafruit does sell the exact same one that we use in the Electron, and it can be found here.
Kyle
Ok thank you for the link!
Be very careful with that battery. Since it was short-circuited as you said, it could be damaged. You can read more about it here, along with the risks and dangers:
If you do replace the battery, be absolutely sure you dispose of it in a responsible manner. Throwing it in the garbage could cause an explosion, such as in the crusher machine in a garbage truck. Also, consider the environmental issues.
If you do decide to continue using the battery, it sounds like the connector is damaged:
A damaged connector can cause intermittent connection issues. Search for a "JST connector" to find a replacement. Be extremely careful that you do not short the battery again during a connector replacement job....
