Device OS 3.1.0-rc.1 Release Candidate is available in the Web IDE, Particle CLI and Workbench for (Photon/P1/Electron/Argon/Boron/B SoM/B5 SoM/Tracker).
Released on June 22nd, 2021
Device OS 3.1 brings support for 256KB application binaries to all Gen 3 platforms (Argon, Boron, B SoM, B5 SoM, Tracker). A few important aspects of this change:
- If using standalone Particle CLI installation, make sure it’s updated to >= 2.12.0 version, which includes support for 256KB applications.
3.1.0-rc.1
FEATURES
- [Gen 3] 256KB application support #2322
- Support for DTLS connection IDs #2249
- GCC 10 support #2288
- [Gen 3] BLE LESC support #2262
- [Gen 3] BLE 5 PHY_CODED (long range) scanning and advertising support #2287 #2298 #2321
- [Tracker] AB1805 native watchdog support #2316
- [Boron / B SoM / Electron] Support for SARA R410 05.12 modem firmware #2317 #2319 #2318
- Add an API to get the maximum supported size of event data #2315
ENHANCEMENTS
- [Argon] Cache ESP32 MAC address in persistent storage to improve boot-up times #2327
- [Cellular] Inhibit Cellular URCs before going into sleep to prevent them from triggering wake-up #2295 #2321
- [Gen 3] Remove XIP support for accessing the external flash #2302 #2321
- [Photon / P1] Enable LTO #2288
- Trigger a compiler error when a function returning a value does not do so #2323
- [Gen 3] Fix non-MBR-based bootloader updates #2327
BUGFIXES
- [Cellular] Prevent ICCID querying errors when not connected to a cellular network by using airplane mode
CFUN=4
#2328 - [Photon / P1] Make sure to close all sockets when deinitializing WICED WLAN connectivity subsystem #2313 #2321
- [Gen 2] Fix unexpected network connection establishment after exiting sleep mode when only
Network.on()
was called #2309 - [Gen 2] Fix unexpected network connection establishment when the modem or WiFi initialization failes, but only
Network.on()
was called #2309 - Correctly restore network interface power state after waking up from
STOP
orULTRA_LOW_POWER
sleep modes #2308 - Fix the issue that the Particle.disconnect() doesn’t clear the auto-connect flag #2306
- [Electron] Fix unintended modem reset after an ongoing network registartion attempt is actively cancelled by the application #2307
- Fix
Particle.unsubscribe()
not preserving system subscriptions #2293 - Querying the value of an empty string variable causes an error #2297
INTERNAL
- [ci] Remove build directory after finishing the build job #2311
- [ci] Fix MarkupSafe weirdness #2314
- Add an integration test to validate network/cloud connection time SLOs #2312 #2320 #2321
- Allow clearing session data and running custom setup code in integration tests #2280
- Add
.bundleignore
for Workbench Device OS source code bundles #2326 - Manage GCC dependencies with
.workbench/manifest.json
d94f08030
Programming and Debugging
