Particle Tools Changelog
January 22nd 2021: Device OS v3.0.0-rc.1
Device OS 3.0.0-rc.1 is the first release candidate on non-LTS feature development branch (3.x). To learn more about our new LTS release line, read our blog post.
3.0.0-rc.1
Highlights
  • [Electron] Modem power-on speed-up
  • [Boron / B SoM] Third-party SIM card initialization bugfixes
  • [Gen 3] UART RX DMA bugfix
  • [Gen 3] BLE, OTAv3, network stack bugfixes
:star2: Be sure to read the full collection of release notes Particle Device OS Updates Thread.
March 16th 2021: Device OS v3.0.0-rc.2
Device OS 3.0.0-rc.2 is the second release candidate on non-LTS feature development branch (3.x). To learn more about our new LTS release line, read our blog post.
3.0.0-rc.2
Highlights
  • [Cellular] Battery presence detection when charging is disabled
  • Increased maximum payload sizes for cloud primitives (publishes, variables, functions)
  • Improved cold and warm boot behavior on B5 SoMs and Trackers
  • System power management subsystem improvements
… and other bugfixes and improvements!
April 8th 2021: Device OS v3.0.0
Device OS 3.0.0 is the latest release on non-LTS (3.x) branch. To learn more about our new LTS release line, read our blog post.
3.0.0
Breaking changes
  • [Cellular] Remove rssi and qual from Cellular.RSSI() #2212
  • [Gen 3] BLE API consistency enhancements #2222
Highlights
  • OTA protocol version 3 (OTAv3) on Gen 3 platforms
  • WiFi scanning support on Tracker
  • Charging management through higher level power management API
  • Network.isOn() and Network.isOff() APIs
  • BLE legacy pairing support and other BLE enhancements
  • New Tracker-specific wake-up options
  • More accurate cellular signal strength/quality percentage calculations
April 15th 2021: Device OS v2.1.0-rc.1 (LTS)
This is the first Release Candidate for the upcoming Device OS release 2.1.0 (LTS) with critical bugfixes and backports from 3.x release line.
2.1.0-rc.1
Highlights
  • This Release Candidate contains a set of critical bugfixes and backports from 3.x release line
  • Backported features:
    • Network.isOn() and Network.isOff() APIs to query the network interface power state #2205
    • [Electron] Proactively attempt to recover from a number of failed cellular registration states #2301
  • Plenty of bugfixes and enhancements!
April 29th 2021: Device OS v2.1.0 (LTS)
This is the first minor Device OS Release in the LTS line with critical bugfixes and backports from 3.x release line.
2.1.0
Highlights
  • This Release contains a set of critical bugfixes and backports from 3.x release line
Plenty of bugfixes and enhancements! :star2: Be sure to read the full collection of release notes Particle Device OS Updates Thread.
June 22nd 2021: Device OS v3.1.0-rc.1
3.1.0-rc.1
Highlights
  • [Gen 3] (Argon, Boron, B SoM, B5 SoM, Tracker) maximum application size has been increased from 128KB to 256KB #2322. A few important aspects of this change:
    1. Compatibility with 128KB applications built with < Device OS 3.1 versions is maintained. Devices can still run them even if other parts have been upgraded to Device OS 3.1+.
    2. Upgrade process OTA (including product-based upgrades) is transparent.
    3. When upgrading locally (using DFU or Serial), make sure to update the bootloader first, as it has some logic managing compatibility between 128KB and 256KB application types. See this page on steps how to perform the update.
    4. If using standalone Particle CLI installation, make sure it’s updated to >= 2.12.0 version, which includes support for 256KB applications.
  • A compiler will trigger an error when a function does not return a value, but was declared with a non-void return type #2323
  • GCC 10 support #2288
  • [Gen 3] BLE LE Secure Connections support #2262
  • [Gen 3] BLE LE Long Range/Coded PHY support #2287 #2298 #2321
  • [Boron / B SoM / Electron] SARA R410 05.12 modem firmware support #2317 #2319 #2318
  • APIs to query maximum payload size for cloud primitives #2315
  • Improvements to Argon boot-up times #2327
  • Improvements to sleep behavior with Cellular specified as a wake-up source #2295 #2321
June 24th 2021: Device OS v2.2.0-rc.1 (LTS)
This is the first Release Candidate for the upcoming Device OS release 2.2.0 (LTS) with critical bugfixes and backports from 3.x release line.
2.2.0-rc.1
Highlights
July 13th 2021: Device OS v3.1.0
Note: This is a Release and may be used for production.
3.1.0
Highlights
August 27th 2021: Device OS v2.2.0-rc.2 (LTS)
This is the second Release Candidate for the upcoming Device OS release 2.2.0 (LTS) with critical bugfixes and backports from 3.x release line.
2.2.0-rc.2
Highlights
  • DTLS session is not cleared on socket errors (e.g. caused by cellular network deregistration), reducing network data required to re-established cloud connection #2335 #2337
  • [Argon / Tracker] Avoid power leakage through ESP32 ESPBOOT pin #2342
  • Fixes parsing of JSON strings with more than 127 tokens #2348
  • Reset scheduled module updates performed by the bootloader in case a second OTA update happens before they are applied (e.g. if System.disableReset() is used to postpone a pending device reset) #2346
September 15th 2021: Device OS v2.2.0 (LTS)
This is the second minor Device OS Release in the LTS line with critical bugfixes and backports from 3.x release line.
2.2.0
Highlights
September 24th 2021: Device OS v2.0.2 (LTS)
2.0.2
Highlights
  • [Electron] Optional feature to use HSE/LSI as RTC clock source instead of LSE (external 32KHz XTAL) #2354
October 6th 2021: Device OS v2.3.0-rc.1 (LTS)
This is the first Release Candidate for the upcoming Device OS release 2.3.0 (LTS) with critical bugfixes and backports from 3.x release line.
2.3.0-rc.1
Highlights
  • [Boron / B SoM ] Support for SARA R510 #2359 #2365
November 12th 2021: Device OS v3.2.0-rc.1
3.2.0-rc.1
Highlights
  • acquireSerialXBuffer() API support for configuring custom buffer sizes for hardware UARTs (e.g. Serial1) #2375
  • [Boron / B SoM] Support for SARA R510 #2359 #2365
  • [Gen 3] BLE: extended advertisement support with Coded PHY #2331
January 18th 2021: Device OS v3.2.0
3.2.0
Highlights
  • Fix hardfault handler to SOS again #2381
  • [Gen 3] Fix LittleFS truncate causing file corruption #268 #2385
  • [Gen 3] HAL - Only skip modules that fail integrity check from module info #2387
January 25th 2022: Device OS v2.3.0 (LTS)
2.3.0
Highlights
  • This Release contains a set of features and one enhancement from 3.x release line to add support for SARA R510 modems
  • [Boron / B SoM / R510] Add additional modem responsiveness check on warm boot to avoid triggering R510-specific initialization issue #2373
March 18th 2022: Device OS v3.3.0-rc.1
3.3.0-rc.1
Highlights
  • [Gen3] BLE Provisioning Mode #2382 #2379 #2405
  • System.off() API support for unsubscribing from system events/handlers #2390
  • Enables stack overflow detection in all builds #2392
  • Adds LOG_C_VARG() logging macro to support vargs from user apps #2393
  • Adds os_thread_dump* introspection functions to wrap the FreeRTOS functions #2394
  • Adds ability to override the panic handler in user applications #2384
  • [gen3] SystemPowerConfiguration::socBitPrecision(uint8_t bits)) API added #2401
April 4th 2022: Device OS v3.3.0
3.3.0
Highlights
  • CoAP Blockwise transfer for Describe messages #2377 #2417
July 28th 2022: Device OS v4.0.0-beta.1
This is the first Device OS Release in the 4.x LTS line, based on new Feature/Enhancements/Bugfixes and Breaking Changes from the 3.x release line.
Note: If you are upgrading from 2.x, please review the changelogs highlights for 3.0.0/3.1.0/3.2.0/3.3.0 below.
Note: Critical Bugfixes from 3.x will already be backported in the latest 2.3.0, and some other Bugfixes may only apply to previous 3.x releases. Internal changes are omitted in the 3.x changelog list below, however the full changelog may be found at the Device OS repo.
4.0.0-beta.1
Breaking changes
  • Deprecate/remove the PRODUCT_ID macro #2446. Users may now use the same binary for multiple Products that share the same device Platform and Functionality. Including this macro will cause a build error and show the following message:
    The PRODUCT_ID macro must be removed from your firmware source code.
    The same compiled firmware binary may be used in multiple products that share the same platform and functionality.
Highlights
  • [deprecation][gen2] supply secure #2442
  • [deprecation] Adds warning to some deprecated API’s that will be removed in Device OS 5.x #2445
  • [deprecation] remove setup_done flag and add deprecation notice #2447
  • [esomx] Adds support for new platform esomx #2443 #2459
  • [gen3][quectel] Adds support for BG95-M1, BG95-MF, BG77, and EG91-NAX #2458
  • [ota] new API System.updateStatus() #2344
  • [gen3] wifi: add dhcp dns info to wifi config #2440
  • [ota] Additional state for firmware update checks #2344
  • Use a custom content type with CID packets when resuming the session #2441
3.3.0
Highlights
3.2.0
Highlights
3.1.0
Highlights
3.0.0
Breaking changes
Highlights
August 19th 2022: Device OS v5.0.0
This is a release on non-LTS feature development branch (5.x). To learn more about our new LTS release line, read our blog post.
5.0.0
Highlights
BREAKING CHANGE
  • [esomx] Remove undefined pins from esomx pinmap #2505
FEATURES & ENHANCEMENTS
  • P2 Support #2466
  • Tracker M Support #2492 #2518 #2522
  • [p2] Allow setting WiFi country code and channel plan #2485 #2473
  • [rtl872x] Implement HAL event group for UART #2493
  • [rtl872x] Implement APIs to set/get BLE address #2508
  • [p2][wifi] Add more complete WiFi network configuration information for P2 #2474
  • [p2][photon2] Add VBAT_MEAS pin and charging indication pin for Photon2 #2482
  • [ethernet][p2] Allow ethernet detection on P2 #2478
  • Register without waiting for CSD connections #2404
August 30th 2022: Device OS v4.0.0 (LTS)
Note: Critical Bugfixes from 3.x will have already been backported in the latest 2.3.0, and some other Bugfixes may only apply to previous 3.x releases. Internal changes are omitted in the 3.x changelog list below, however the full changelog may be found at the Device OS repo.
4.0.0
Breaking changes
Highlights
  • [deprecation][Gen 2] Supply secure #2442
  • [deprecation] Remove setup_done flag and add deprecation notice #2447
  • [E SoM X] Adds support for new platform E SoM X #2443 #2459
  • [Gen 3][Quectel] Adds support for BG95-M1, BG95-MF, BG77, and EG91-NAX #2458
  • [OTA] New API System.updateStatus() #2344
  • [Gen 3] wifi: add DHCP and DNS info to wifi config #2440
  • [OTA] Additional state for firmware update checks #2344
  • System.hardwareInfo() API #2526 #2529
  • Ensure that RTOS context switch is performed in tight delay(1) loops #2519 #2520 #2524
3.3.0
Highlights
3.2.0
Highlights
3.1.0
Highlights
3.0.0
Breaking changes
Highlights
