Hi.
I’m having trouble with the Particle-Dev Application. It won’t compile,
I keep getting: > Uncaught TypeError: path must be a string
at TypeError (native)
at Object.fs.openSync (fs.js:584:18)
at Object.module.(anonymous function) [as openSync] (ATOM_SHELL_ASAR.js:159:20)
at Object.fs.readFileSync (fs.js:431:33)
at Object.fs.readFileSync (ATOM_SHELL_ASAR.js:427:29)
at C:\Users\Davidm\AppData\Local\particledev\app-1.8.0\resources\app.asar\node_modules\particle-dev\lib\main.js:1030:40
at Object.module.exports.minBuildTargetRequired (C:\Users\Davidm\AppData\Local\particledev\app-1.8.0\resources\app.asar\node_modules\particle-dev\lib\main.js:498:14)
at C:\Users\Davidm\AppData\Local\particledev\app-1.8.0\resources\app.asar\node_modules\particle-dev\lib\main.js:941:24
at Object.module.exports.loginRequired (C:\Users\Davidm\AppData\Local\particledev\app-1.8.0\resources\app.asar\node_modules\particle-dev\lib\main.js:450:14)
at Object.module.exports.compileCloud (C:\Users\Davidm\AppData\Local\particledev\app-1.8.0\resources\app.asar\node_modules\particle-dev\lib\main.js:939:19)
at atom-workspace.<anonymous> (C:\Users\Davidm\AppData\Local\particledev\app-1.8.0\resources\app.asar\node_modules\particle-dev\lib\main.js:146:24)
at CommandRegistry.module.exports.CommandRegistry.handleCommandEvent (C:\Users\Davidm\AppData\Local\particledev\app-1.8.0\resources\app.asar\src\command-registry.js:260:29)
at CommandRegistry.handleCommandEvent (C:\Users\Davidm\AppData\Local\particledev\app-1.8.0\resources\app.asar\src\command-registry.js:3:61)
at CommandRegistry.module.exports.CommandRegistry.dispatch (C:\Users\Davidm\AppData\Local\particledev\app-1.8.0\resources\app.asar\src\command-registry.js:160:19)
at executeCallback (C:\Users\Davidm\AppData\Local\particledev\app-1.8.0\resources\app.asar\node_modules\tool-bar\lib\tool-bar-button-view.js:123:19)
at ToolBarButtonView._onClick (C:\Users\Davidm\AppData\Local\particledev\app-1.8.0\resources\app.asar\node_modules\tool-bar\lib\tool-bar-button-view.js:82:9)
The code works fine online. I’ve checked for file name conventions, what am I missing?
