Particle Dev Compile time access to type of device?
I’m enjoying the nice tight compose-edit-compile-flash cycle I get with the Photon and Particle Dev. I no longer bother with local compilation which avoids all sorts of version control issues. Thank you.
Some of my code is device dependent, for example:
#ifdef PHOTON
    setADCSampleTime(ADC_SampleTime_112Cycles); // Photon specific code
#endif
It isn’t a big issue but as the compiler obviously knows whether the target is Core or Spark, is there a system defined variable that I can use instead of adding my own #define PHOTON ?
I appreciate it isn’t as important as the bug fixes the clever Particle guys are working on but maybe it is already done and I just haven’t found it.
I think you can try something like:
#if PLATFORM_ID==6
//blah blash
#endif
That works @kennethlimcp! Now I only need one version of my software. Thank you.
