OK, I've been giving this a try, and getting a little further, but am getting stuck.
I have the debugger connected to the Dim blue D7 electron with ground, D6 and D7, and both are connected to my laptop (Mac) by USB.
The directions say to put the device into DFU mode, but of course the the device is unresponsive, and I'm unable to do that.
Is this because I cannot get to DFU mode? I'm very confused about what to try next.
below is what I put into the terminal and the response...
I do the following:
cd ~/.particle/toolchains/openocd/
cd 0.10.0-particle.1
then
bin/openocd -f interface/cmsis-dap.cfg -f target/stm32f2x.cfg \
-c "adapter_khz 1000" \
-c "transport select swd" \
-c "init" \
-c "reset halt" \
-c "flash protect 0 0 0 off" \
-c "program /Users/myuser/Downloads/bootloader-1.0.1-electron.bin verify 0x08000000" \
-c "flash protect 0 0 0 on"
-c "exit"
I then get the following response:
Open On-Chip Debugger 0.10.0 (2019-01-29-17:30)
Licensed under GNU GPL v2
For bug reports, read
OpenOCD: Bug Reporting
Info : auto-selecting first available session transport "swd". To override use 'transport select <transport>'.
adapter speed: 1000 kHz
adapter_nsrst_delay: 100
none separate
cortex_m reset_config sysresetreq
Info : CMSIS-DAP: SWD Supported
Info : CMSIS-DAP: Interface Initialised (SWD)
Info : CMSIS-DAP: FW Version = 1.10
Info : SWCLK/TCK = 1 SWDIO/TMS = 1 TDI = 0 TDO = 0 nTRST = 0 nRESET = 1
Info : CMSIS-DAP: Interface ready
Info : clock speed 1000 kHz
Info : SWD DPIDR 0x2ba01477
Info : stm32f2x.cpu: hardware has 6 breakpoints, 4 watchpoints
-c "init" \
-c "reset halt" \
-c "program /Users/jimlivingston/Downloads/bootloader-1.0.1-electron.bin verify 0x08000000" \
-c "flash protect 0 0 0 on" \
-c "exit"
Polling target stm32f2x.cpu failed, trying to reexamine
Error: Could not initialize the debug port
Examination failed, GDB will be halted. Polling again in 100ms
Examination failed, GDB will be halted. Polling again in 300ms
Error: error writing data: (null)
Error: CMSIS-DAP command CMD_DISCONNECT failed.
Error: CMSIS-DAP command CMD_CONNECT failed.
