Looking at the documentation for the CLI command “particle compile”, the P1 is missing from the list?
https://docs.particle.io/reference/cli/#particle-compile
While somewhat alike the Photon, the code won’t compile if you use any of the P1 specific pins (P1S1 and such). Any tricks to compile for the P1?
@jenschr, try specifying p1 instead of P1 as the device type. Seems to work for me.
@jenschr particle compile p1 filename is the command I use to compile for P1. If you are using pins named P1S1, the code won’t work for compiling on Photon platform as these pins names don’t exist.
ahh. they’ve just forgotten to add it to the Docs then
