Particle Cli not installing
Ah, sorry, that path you can’t find is actually only connected to Particle Dev, so you won’t need it.
But these parts of your PATH might be a clue for your problem.
You have got C:\Program Files\nodejs and C:\Particle\Tools\NodeJS.
Any reason why you’ve got two sets of nodejs?
And I can’t see the %appdata%\Roaming\npm in your PATH, can you check if it exists?
This directory should actually contain the particle-cli module.
If this directory exists, try adding it to your PATH manually (and remove the second NodeJS from it).
What does npm version report (maybe executed from within both of your directories)?
two node js because i had installed it and forgot to take it off of the toolkit installation. and npm version outputs: http://prntscr.com/8yt413. and particle-cli is in the npm-cache.
Have you actually got the full module in npm-cache or rather only the packed particle.tgz?
This is how it looks on mine (although I’m still sticking with Node v0.12.4)
And there is a particle.cmd file in %appdata%\Roaming\npm\ too.
Its just the package.tgz
The installation of CLI is driving me nuts :stuck_out_tongue_closed_eyes:
Just give npm uninstall -g particle-cli and a subsequent npm install -g particle-cli another try.
If this doesn’t work, remove all instances of NodeJS and try the installer afresh.
particle-cli installation fails no matter what. even if i install it after all of the stuff ive been told to do.
i have a skype if someone wants to call me and go from there…
I’ve run out of ideas, but I’ve asked some of the more brilliant people to have a look into your problem.
I had thought of offering a TeamViewer session to just play through what I’d do if my machine would not work (providing you’d trust me enough to let me fiddle on your machine).
But let’s wait first if someone has got the right idea.
My timezone is UTC+1.
I FINALLY GOT IT TO WORK. I connected to it using putty with a serial.
Huh? Got what working?
How would PuTTY help installing CLI?
Or do you mean you got around the need for CLI by using another aporach - e.g. for setting WiFi credentials?
If that, then asking the correct question would have safed you a lot of trouble :wink:
i didnt know what to ask… but yeah
I recently had problems reinstalling particle-cli (failure at serialport) but then I found these posts:
and
I followed the suggestion to do the npm install from the Visual Studio Command Prompt:
Try running the npm install commands from a MSVS command prompt.
    Find it at Start menu > Microsoft Visual Studio 201X > Visual Studio Tools > Open Visual Studio 201X Tools Command Prompt or run the <Program Files>\<VS dir>\Common7\Tools\VsDevCmd.bat from a command prompt.
and the installation proceeded flawlessly.
