Particle CLI Errors out
Recently, I have found the particle CLI tool becoming very slow on Windows.
The main problem is that when ever I try to run ‘particle identify’, I get the following error:
$ particle identify
Cannot find module 'safer-buffer'
I have upgraded Node, npm and particle-cli all with no change. The particles are in listening mode.
What else should I be trying?
The Particle CLI installer installs an isolated version of node. You likely now have conflicting global (-g) install and isolated install versions. I recommend removing the -g version:
  • Open a Command Prompt window and run the command:
npm uninstall -g particle-cli
If you get an error about npm not found, just continue onto the next step. This removes a previous manual install.
There are additional tips here.
To upgrade the CLI, use the command:
particle upgrade-cli
Don’t use the npm install -g particle-cli option, as that will break your install again.
