Particle cli broken for flashing
I have been using the spark-cli command line forever with great success. It just started giving me:
flash device said  {"error":"invalid_token","error_description":"The access token provided has expired."}
even though the token shown online is good. So I updated to the particle cli. Now I get this when trying to flash:
user@user-Peppy:~/Dropbox/dev/spark$ particle flash 5 lamptest1
TypeError: Cannot call method 'apply' of undefined
    at Object.extend.flashCloud (/usr/local/lib/node_modules/particle-cli/commands/FlashCommand.js:128:26)
    at Object.extend.flashSwitch (/usr/local/lib/node_modules/particle-cli/commands/FlashCommand.js:120:29)
    at Object.BaseCommand.runCommand (/usr/local/lib/node_modules/particle-cli/commands/BaseCommand.js:110:17)
    at Object.Interpreter.runCommand (/usr/local/lib/node_modules/particle-cli/lib/interpreter.js:98:13)
    at Object.Interpreter.handle (/usr/local/lib/node_modules/particle-cli/lib/interpreter.js:56:18)
    at Object.<anonymous> (/usr/local/lib/node_modules/particle-cli/bin/particle.js:20:5)
    at Module._compile (module.js:456:26)
    at Object.Module._extensions..js (module.js:474:10)
    at Module.load (module.js:356:32)
    at Function.Module._load (module.js:312:12)
xubuntu 14.04
node v0.10.38
if I use node 0.12.5 then the error looks like this:
Error loading command /usr/local/lib/node_modules/particle-cli/commands/CloudCommands.js Error: Cannot find module '/usr/local/lib/node_modules/particle-cli/node_modules/serialport/build/serialport/v1.7.4/Release/node-v14-linux-x64/serialport.node'
Error loading command /usr/local/lib/node_modules/particle-cli/commands/SerialCommand.js Error: Cannot find module '/usr/local/lib/node_modules/particle-cli/node_modules/serialport/build/serialport/v1.7.4/Release/node-v14-linux-x64/serialport.node'
		return cloud.flashCore.apply(cloud, arguments);
TypeError: Cannot read property 'flashCore' of undefined
    at Object.extend.flashCloud (/usr/local/lib/node_modules/particle-cli/commands/FlashCommand.js:128:15)
    at Module._compile (module.js:460:26)
    at Object.Module._extensions..js (module.js:478:10)
    at Module.load (module.js:355:32)
    at Function.Module._load (module.js:310:12)
Do a particle login
