I haven't been using this long. I forgot how to fix this thing.
I've deleted sparkcore device from build.particle.io
I tried reset.
particle flash --factory tinker
particle flash --usb cc3000
particle flash --usb tinker
particle setup
Still show up Please login - it appears your access_token may have expired
No luck. I did particle doctor.
Claiming USB DFU Interface...
Setting Alternate Setting #1 ...
dfuIDLE, continuing
Device returned transfer size 1024
DfuSe interface name: "SPI Flash : SST25x"
Downloading to address = 0x00002000, size = 610
Download [=========================] 100% 610 bytes
Download done.
File downloaded successfully
Transitioning to dfuMANIFEST state
Saved!
attempting to add a new public key for device 5******************************
submitPublicKey got error: invalid_token
Make sure your device is in DFU mode (blinking yellow), and that your computer is online.
Error - invalid_token
How do you fix this?
