hi every time i flash the firmware that i attach here, my argon blinks red 8 times. Do you know why?
#include "Particle.h"
#include <MQTT.h>
#include <Adafruit_Sensor.h>
#include <Grove_ChainableLED.h>
#include <TCA9548A-RK.h>
#include <Adafruit_MLX90393_SSSA.h>
#include <Adafruit_BNO055_Library_SSSA.h>
/* BNO055
Connections
Connect SCL to analog 5
Connect SDA to analog 4
Connect VDD to 3.3V DC
Connect GROUND to common ground
SYSTEM_MODE(AUTOMATIC);
SYSTEM_THREAD(ENABLED);
/* Set the delay between fresh samples */
#define BNO055_SAMPLERATE_DELAY_MS (100)
#define TCAADDR 0x70
#define MLX90393_CS 10
#define MAGADDR 0X0C
// Check I2C device address and correct line below (by default address is 0x29 or 0x28)
// id, address
Adafruit_BNO055 bno = Adafruit_BNO055(55,0x28);
Adafruit_MLX90393 sensor1 = Adafruit_MLX90393();
Adafruit_MLX90393 sensor2 = Adafruit_MLX90393();
Adafruit_MLX90393 sensor3 = Adafruit_MLX90393();
Adafruit_MLX90393 sensor4 = Adafruit_MLX90393();
Adafruit_MLX90393 sensor5 = Adafruit_MLX90393();
void tcaselect(uint8_t i)
if (i > 7) return;
Wire.beginTransmission(TCAADDR);
Wire.write(1 << i);
Wire.endTransmission();
//Serial.println("Orientation Sensor Raw Data Test"); Serial.println("");
Wire.begin();
/* Initialise the sensor */
/*----------------IMU----------------------*/
tcaselect(5);
delay(100);
if(!bno.begin())
{/* There was a problem detecting the BNO055 ... check your connections */
Serial.print("Ooops, no BNO055 detected ... Check your wiring or I2C ADDR!");
else{
//Serial.println(" IMU ok");
bno.setExtCrystalUse(true);
delay(100);
/*-------------SENSORE 1----------------------*/
tcaselect(0);
delay(100);
if (! sensor1.begin_I2C(0x0C)) { // hardware I2C mode, can pass in address & alt Wire
Serial.println("No sensor 1 found ... check your wiring?");
else{
//Serial.println(" S1 ok");
sensor1.setGain(MLX90393_GAIN_5X);
sensor1.setResolution(MLX90393_X, MLX90393_RES_16);
sensor1.setResolution(MLX90393_Y, MLX90393_RES_16);
sensor1.setResolution(MLX90393_Z, MLX90393_RES_16);
// Set oversampling
sensor1.setOversampling(MLX90393_OSR_0);
// Set digital filtering
sensor1.setFilter(MLX90393_FILTER_5);
/*---------------SENSORE 2----------------------------------*/
tcaselect(1);
delay(100);
if (! sensor2.begin_I2C(0x0C)) { // hardware I2C mode, can pass in address & alt Wire
Serial.println("No sensor 2 found ... check your wiring?");
else{
//Serial.println(" S2 ok");
sensor2.setGain(MLX90393_GAIN_5X);
sensor2.setResolution(MLX90393_X, MLX90393_RES_16);
sensor2.setResolution(MLX90393_Y, MLX90393_RES_16);
sensor2.setResolution(MLX90393_Z, MLX90393_RES_16);
// Set oversampling
sensor2.setOversampling(MLX90393_OSR_0);
sensor2.setFilter(MLX90393_FILTER_5);
/*-------------SENSORE 3--------------------------*/
tcaselect(2);
delay(100);
if (! sensor3.begin_I2C(0x0C)) { // hardware I2C mode, can pass in address & alt Wire
Serial.println("No sensor 3 found ... check your wiring?");
else{
//Serial.println(" S3 ok");
sensor3.setGain(MLX90393_GAIN_5X);
sensor3.setResolution(MLX90393_X, MLX90393_RES_16);
sensor3.setResolution(MLX90393_Y, MLX90393_RES_16);
sensor3.setResolution(MLX90393_Z, MLX90393_RES_16);
// Set oversampling
sensor3.setOversampling(MLX90393_OSR_0);
sensor3.setFilter(MLX90393_FILTER_5);
/*-------------SENSORE 4--------------------------*/
tcaselect(3);
delay(100);
if (! sensor4.begin_I2C(0x0C)) { // hardware I2C mode, can pass in address & alt Wire
Serial.println("No sensor 4 found ... check your wiring?");
else{
//Serial.println(" S4 ok");
sensor4.setGain(MLX90393_GAIN_5X);
sensor4.setResolution(MLX90393_X, MLX90393_RES_16);
sensor4.setResolution(MLX90393_Y, MLX90393_RES_16);
sensor4.setResolution(MLX90393_Z, MLX90393_RES_16);
// Set oversampling
sensor4.setOversampling(MLX90393_OSR_0);
sensor4.setFilter(MLX90393_FILTER_5);
/*-------------SENSORE 5--------------------------*/
tcaselect(5);
delay(100);
if (! sensor5.begin_I2C(0x0C)) { // hardware I2C mode, can pass in address & alt Wire
else{
//Serial.println(" S5 ok");
sensor5.setGain(MLX90393_GAIN_1X);
sensor5.setResolution(MLX90393_X, MLX90393_RES_16);
sensor5.setResolution(MLX90393_Y, MLX90393_RES_16);
sensor5.setResolution(MLX90393_Z, MLX90393_RES_16);
// Set oversampling
sensor5.setOversampling(MLX90393_OSR_0);
sensor5.setFilter(MLX90393_FILTER_5);
Arduino loop function, called once 'setup' is complete (your own code
should go here)
delay(1000);
tcaselect(5);
sensors_event_t event;
bno.getEvent(&event);
if(!bno.begin())
else{
delay(100);
imu::Vector<3> mag= bno.getVector(Adafruit_BNO055::VECTOR_MAGNETOMETER );
/* Display the quat data */
float Magx,Magy,Magz;
float x1, y1, z1;
float x2, y2, z2;
float x3, y3, z3;
float x4, y4, z4;
float x5, y5, z5;
Magx=mag.x();
Magy=mag.y();
Magz=mag.z();
delay(200);
Particle.publish("MagX: ", String(Magx));
delay(1);
Particle.publish("MagY: ", String(Magy));
delay(1);
Particle.publish("MagZ:",String(Magz));
delay(1);
// get X Y and Z data at once
tcaselect(0);
sensor1.readData(&x1, &y1, &z1);
delay(100);
Particle.publish("X1: ",String(x1));
delay(500);
Particle.publish("Y1: ",String(y1));
delay(500);
Particle.publish("Z1: ",String(z1));
delay(500);
if (sensor1.readData(&x1, &y1, &z1)) {
} else {
Serial.println("Unable to read XYZ data from the sensor 1.");
tcaselect(1);
sensor2.readData(&x2, &y2,&z2);
delay(100);
Particle.publish("X2: ",String(x2));
delay(500);
Particle.publish("Y2: ",String(y2));
delay(500);
Particle.publish("Z2: ",String(z2));
delay(500);
if (sensor2.readData(&x2, &y2,&z2)) {
} else {
Serial.println("Unable to read XYZ data from the sensor 2.");
tcaselect(2);
sensor3.readData(&x3, &y3, &z3);
delay(100);
Particle.publish("X3: ",String(x3));
delay(500);
Particle.publish("Y3: ",String(y3));
delay(500);
Particle.publish("Z3: ",String(z3));
delay(500);
if (sensor3.readData(&x3, &y3, &z3)) {
} else {
Serial.println("Unable to read XYZ data from the sensor 3.");
tcaselect(3);
sensor4.readData(&x4, &y4, &z4);
delay(100);
if (sensor4.readData(&x4, &y4, &z4)) {
} else {
Serial.println("Unable to read XYZ data from the sensor 4.");
tcaselect(4);
sensor5.readData(&x5, &y5, &z5);
delay(100);
Particle.publish("X5: ",String(x5));
delay(500);
Particle.publish("Y5: ",String(y5));
delay(500);
Particle.publish("Z5: ",String(z5));
delay(500);
if (sensor5.readData(&x5, &y5, &z5)) {
} else {
Serial.println("Unable to read XYZ data from the sensor 5.");
delay(100);
