Hi ,
Is it possible to publish directly to an MQTT server from Particle Argon device without publishing to particle.io by coding in firmware?
Thanks in Advance
Hi ,
Thanks in Advance
Can you clarify that?
How would you instruct the device to do what you want without programming the device to do that - how would the device know what you expect it to do?
However, you may want to have a look at this
https://build.particle.io/libs/MQTT/0.4.31/tab/example/mqttqostest.ino
This example only publishes to MQTT without going via the Particle cloud pub/sub route.
Hi, I was looking to publishes to MQTT without going via the Particle cloud pub/sub route. This example will help. Thanks a million.
