Particle Argon does not go breathing Cyan mode when connected to WiFi that is not connected to internet
I am trying to create a local server without the connection to internet. I have created a TCP server for my Aargons to connect to. But the problem is that code seem to be not running and the module keeps flashing green. I would appreciate any help.
I have attached the code below:
TCPClient client;
    WiFi.setCredentials("xxxx");
    Serial.begin(115200);
    client.connect('192.168.01', 3000);
    Serial.print("Trying to connect to server");
    if(client.connect('192.168.01', 3000)){
        Serial.print("Connected to Mona Server");
    else Serial.print("Connection Failed");
  if (client.status()){
      Serial.print("Still connected");
      client.println("Hello port is 80.0"); // sending data
  else Serial.print("Not connected\n");
Breathing cyan explicitly means connected to the Particle cloud - no internet, no cloud connection.
https://docs.particle.io/tutorials/device-os/led/argon/#connected
How to get your code running without internet was already addressed countless times before
https://community.particle.io/search?q=without%20interne
