BOKRA has developed a Dual Slot Adapter for installing modules with the Adafruit Feather and mikroBUS form factor. This makes it possible to carry out projects based on Particle Xenon, Argon and Boron using more than 600 popular Click modules with mikroBUS bus from Mikroelektronika.
The module power supply is non-isolated, in the range from 9VDC to 36VDC. The module converts the input power to the output, 5VDC. The maximum current is 1A. There are two connectors for distributing 5VDC to other modules and a connector for transmitting VIN input voltage to other modules.
You can purchase the adapter here: https://www.tindie.com/products/bokra/adapter-for-adafruit-feather/
