P1 PCB Design Psuh button Switch Question
Hello,
I am fairly new to the particle photon and I am currently making a pcb with the P1 module. On the P1 datasheet, there is a switch that controls the setup and reset pin and I was wondering if a off-mom tactile switch rated for 12volts and 50ma will be ok. I tried looking buying the button that is used in the particle photon but those are not available for purchase and I think this should be the next best thing.
This is the switch I am planning on using.
https://www.digikey.com/product-detail/en/c-k/PTS645SK50SMTR92-LFS/CKN9087CT-ND/1146813
@cleverdragon1, yup, that will do fine. Any normally open, momentary push-button will do. :wink:
Can you explain how you extend switch? Is ther a way to use silicon button pad over photon?
