Working with Photon P0. Can’t get it out of safe mode.
Used CLI tools to:
update
flash tinker
doctor (it fails with undefined when trying to set the antenna)
Can communicate with the cloud and IOS app
Tried Blink an LED
I am on a Macbook. When I do:
particle serial list - it does list the /dev/tty.usbmodem1441 - Photon
particle serial inspect - Could not get inspect device: Serial timed out
I tried a different USB cable and a different USB c adaptor, same results
Are you in listening mode (blinking dark blue)? Hold down SETUP/MODE if you are not in that mode before doing particle serial inspect. Sorry I forgot to mention that.
