Option to compile locally not available?
In Particle Workbench, after creating a new project, I don’t see an option to compile locally, which it sounds like I should be seeing.
When I choose Install Local Compiler I get a message that the toolchain is available, and .particle/toolchains/gcc-arm/5.3.1 seems to have lots of goodness inside.
Any ideas?
Are you using ctrl-shift-P Show Command Palette? That only lists Particle: Cloud Compile for me. However, when I use ctrl-shift-B Run Build Task I get the option to Particle: Compile application (local) and also to flash locally.
Hope this helps,
digitalhack
Ah, there it is, thank you very much!
