I would like to use this with Particle Photon.
There is a version for ESP32 but nothing for Particle
Is there already someone using it or started to port it to this plattform?
Hello,
did you get OPC UA running on particle ?
franck
Hi Frank,
I got it running on ESP32. I’ll try to do the same with particle. But at the moment a have not enough time to go ahead.
Did you try?
Cheers,
Beat
Wondering if anyone has tinkered with OPC UA on Particle yet? I’m seeing this requirement (along with IO-Link) emerge more frequently as both standards have found good footing in the industrial IoT space. Sam
