[Old Spark core] Unable to setup device
@raiderj,
your steps are not that correct and i’m not sure where you get the instructions from.
So for an old core,
  1. Install particle-cli
  2. Run particle flash --factory tinker
  3. Run particle flash --usb cc3000 (it will blink magenta and eventually revert to blinking yellow)
  4. Run particle flash --usb tinker
  5. Run particle serial wifi
Hope this helps for the people stumbling over this. Also changed your topic title to reflect the issue better!
