I wrote a code to run on electron board. Code works fine. But when I tried to run it offline,( I downloaded this firmware: https://github.com/spark/firmware/tree/latest). It gives me error that example, utils.h: no such file or directory. Actually, My header file is in different folder than my application.cpp file. So it’s like in user/applications folder , there is myapp folder inside this folder I have application.cpp file and I made a separate folder containing header files, that is user/applications/headers. Soo now when I run command from modules folder that is make PLATFORM=electron APP=myapp, it gives me the error that I said above. I think there is need to do some changes in Makefile. Can please anyone give me some idea, how can I resolve it?
Hey thanks for your reply, but I don’t want to do this #include subdirectory/library.h as it’s not a good practice. I want to make some changes in makefile so that my code gets build. In user/applications there is build.mk. INCLUDE_DIRS += $(SOURCE_PATH)/$(USRSRC) # add user sources to include path I found this in build.mk so using this I gave path of my header.
for example, INCLUDE_DIRS += $(SOURCE_PATH)/$(USRSRC)/header # add user sources to include path
