I am wondering if someone could help me compile and include external library into my application. I’ve looked at the docs, but haven’t had any luck yet.
As some background, I am working on a product, and would like to share libraries across multiple applications, such as factory test app, manufacturing, board bringup, etc. I am compiling everything locally so I can make modifications to particle firmware code, and would like to keep all libraries on my local machine.
My folder structure is the following:
top_dir
apps
- test_project
-- firmware
--- test_project.cpp
lib
- test_lib
-- test_lib
--- test_lib.cpp
--- test_lib.h
submodules
- particle_firmware
I would like to include test_lib.h in my test_project.cpp app. I’m compiling from the top directory with the command: ./po electron build apps/$APP_TO_BUILD where ./po is the po-util executable
If it helps, I’m using a modified version of po-util. I’m able to compile successfully without trying to include test.h into my program, but when compiling with #include “test.h” in my program, I get an error. I’ve tried the instructions at https://github.com/spark/firmware/blob/develop/docs/build.md#external_libs but still haven’t had any luck.
Any help figuring this out would be much appreciated!
Thank you
I could assist with CLI compiling and native local toolchain but po-util is @nrobinson2000’s project.
Hi @lbruder827,
Have you tried using the structure I designed specifically for po-util?
You can create a project using:
po electron init <PROJECT_NAME>`
Also, I’d recommend trying po-util’s built-in library manager.
The quickest way to use test_lib with your project would be to run po lib and then copy the test_lib directory with the .cpp and .h inside to ~/.po-util/lib
Then, in your project you could do:
$ po lib add test_lib
Using po-util it was designed to be used, your projects (“apps”) would be created in top_dir like this:
top_dir/
- test_project/
-- firmware/
--- main.cpp
- test_project1/
-- firmware/
--- main.cpp
Your test_lib library would be in ~/.po-util/lib like this:
~/.po-util/lib/
- test_lib/
-- test_lib.cpp
-- test_lib.h
How have you modified po-util?
Thank you, I just got this working, but had to repoint some of the things to my local repo and make a few modifications to do relative symlinks instead of absolute since multiple people will be contributing to my repo. Here is my updated po-util #!/bin/bash# __ __ __# - Pastebin.com.
Great! Thanks for using po-util.
I really appreciate the work you put into it! It’s working very well!
Interesting Modifications…
If I were you I’d create a fork of po-util on GitHub so others could use your changes and so you could pull in any new changes I make.
