oAuth and multiple Redirect URLs
Is there a way to create an oAuth Access Token for an application (Alexa Home Skill) that allow for multiple possible Redirect URL’s??
@ScruffR this is for you my friend!
Let me ping someone that might be able to help, @rickkas7 or @ParticleD are you able to assist?
I’m sorry, I don’t understand the question.
When you go through an oauth flow, you specify a redirect url. This url is held also in the oauth config for the specific token, so the requesting call can not just say post the token to some other website. Amazon Alexa apps can specify 3 different oauth redirect urls depending on region, buy your system only allows the setup on a single end point in the oauth setup.
@KyleG @rickkas7 can I get some love here on this question?
