Hi all,
How can I use cryptographic functionalities of nRF52840 from Particle deviceOS?
Nordic Semiconductor provides a SDK with a lot of interesting libraries. How can I access to them from Boron?
https://infocenter.nordicsemi.com/topic/com.nordic.infocenter.sdk5.v15.3.0/lib_crypto.html
Thank you,
Manuel Montenegro
I’m hopeful for the same thing. I’ve seen a number of people looking to embed other crypto libraries like mbed TLS in their application, but that uses a lot of space and doesn’t use the hardware crypto.
From some topics I’ve read a lot of the libraries might currently be pruned out of the firmware during compile currently though. I’ve opened Feature Request: DTLS support because it seems this support should be easily included as it’s being used.
I haven’t tried it yet, but I hear if you compile a monolithic firmware you should be able to access everything.
I have been trying to get some results.
I’m developing over deviceOS 1.2.0-beta.1 and compiling with debug option from Workbench IDE in order to get a monolithic binary file.
My goal is to use Elliptic Curve in order to generate a key pair using nRF52840 and sign/verify a JSON. This will help in the implementation of JWT (JSON Web Token).
Anyway, I saw this code on deviceOS ecp_alt_cc310.c.
CC310_OPERATION(CRYS_ECPKI_GenKeyPair( pRndState, RYS_RND_GenerateVector, domain,UserPrivKey, UserPublKey, TempECCKGBuff, FipsBuff ), error);
So, I think I can use CC310 libraries present on nRF52840 SDK. This is, CryptoCell API.
I have developed the following code:
#include "ssi_pal_types.h"
#include "ssi_pal_mem.h"
#include "sns_silib.h"
#include "crys_ecpki_build.h"
#include "crys_ecpki_ecdsa.h"
#include "crys_ecpki_dh.h"
#include "crys_ecpki_kg.h"
#include "crys_ecpki_domain.h"
CRYS_RND_State_t* rndState_ptr;
CRYS_RND_WorkBuff_t* rndWorkBuff_ptr;
CRYS_RndInit(rndState_ptr, rndWorkBuff_ptr);
SaSiRndGenerateVectWorkFunc_t rndGenerateVectFunc = CRYS_RND_GenerateVector;
const CRYS_ECPKI_Domain_t *pDomain;
CRYS_ECPKI_DomainID_t domainId = CRYS_ECPKI_DomainID_secp256k1;
pDomain = CRYS_ECPKI_GetEcDomain(domainId);
CRYS_ECPKI_UserPrivKey_t UserPrivKey1;
CRYS_ECPKI_UserPublKey_t UserPublKey1;
CRYS_ECPKI_KG_TempData_t *TempECCKGBuffptr;
CRYS_ECPKI_KG_TempData_t TempECCKGBuff;
TempECCKGBuffptr = (CRYS_ECPKI_KG_TempData_t*)&TempECCKGBuff;
CRYS_ECPKI_KG_FipsContext_t FipsBuff;
int ret = CRYS_ECPKI_GenKeyPair
rndState_ptr,
rndGenerateVectFunc,
pDomain,
&UserPrivKey1,
&UserPublKey1,
TempECCKGBuffptr,
&FipsBuff
if (ret != CRYS_OK)
Serial.println(ret,HEX);
} else {
Serial.println("SUCCESS");
void loop() {}
But the function returns the error “F00891”.
How can I generate a key pair using CryptoCell? This seems like deviceOS allows the use of CC310 using mbedtls.
Any idea?
Thank you,
Manuel
