Hi All,
I have been using the OneWire library and Spark-Dallas-Temp to compile with no problems. This am when I tried to include Blynk the IDE made me move to the new library manager.
Now the IDE cannot find the Onewire and won’t compile.
Here what the error message is:
In file included from /src/onewireds18b20.cpp:5:0:
lib/spark-dallas-temperature/src/spark-dallas-temperature.h:27:36: fatal error: ../OneWire/OneWire.h: No such file or directory
#include "../OneWire/OneWire.h"
***compilation terminated.***strong text
***make[1]: *** [../build/target/user/platform-6src/onewireds18b20.o] Error 1***
***make: *** [user] Error 2***
My messy code follows:
#include <OneWire.h>
#include <spark-dallas-temperature.h>
//#include <blynk.h>
#include "lib1.h"
#define ONE_WIRE_BUS D2 //data on pin d2
#define BLUE_LED D7
//#define TEMP_PWR D5
//#pragma SPARK_NO_PREPROCESSOR
double tempc = 0.0;
double tempf = 10.0;
double maxf = 0.0;
double minf = 125.0;
double temp_minf_floor = -10.0;
double tempf_work = 0.0;
//double tempMinNotify = 63.0;
char TempZone1[64];
int rssi =0;
double LowAlarmTemp= 45.00;
double LowAlarmSentClearTemp = 53.0 ;
int LowAlarmSent = 0;
const char version[ ] = "TempFreeze V1.4 Blynk 2-3-17";
double loop_counter = 0;
double sample_count = 10;
const char webhookTemp[] = "TempAlarm"; // This is integrated with PushOver
OneWire oneWire(ONE_WIRE_BUS); // Setup a oneWire instance to communicate with any OneWire devices
DallasTemperature sensors(&oneWire); // Pass our oneWire reference to Dallas Temperature.
void setup(void)
sensors.begin(); // IC defaults to 9 bit. If you have trouble consider changing to 12.
//Particle.variable("tempc", &tempc, DOUBLE); //expose vars to web interface
//Particle.variable("MaxF", &maxf, DOUBLE);
//Particle.variable("MinF", &minf, DOUBLE);
Particle.variable("tempf", &tempf, DOUBLE);
Particle.variable("rssi", &rssi, INT);
//Particle.variable("LoopCnt", &loop_counter, DOUBLE);
Particle.variable("AlarmSent", &LowAlarmSent, INT);
Particle.variable("Version", version, STRING);
Particle.variable("LowAlarmTemp", &LowAlarmTemp, DOUBLE);
pinMode(BLUE_LED, OUTPUT);
//pinMode(TEMP_PWR, OUTPUT);
void loop(void)
rssi=WiFi.RSSI();
//digitalWrite (TEMP_PWR, HIGH); // GPIO 3.3 V Power to Temperature Sensor
if ( loop_counter > sample_count ) {
sensors.requestTemperatures(); // Send the command to get temperatures from all sensors on the one wire bus
tempc = sensors.getTempCByIndex(0); // 0 refers to the first IC on the wire
loop_counter = 0;
Serial.print(" C ");
Serial.print(tempc);
Serial.println(" ");
tempf_work = (tempc * 9.0 / 5.0) + 32.0;
if ( tempf_work >= temp_minf_floor ){
if ( tempf_work > maxf )
maxf = tempf_work;
if ( tempf_work < minf )
minf = tempf_work;
tempf = tempf_work; // make it offical
//sprintf(TempZone1, "Low Temp Alarm! Temp: %d F", int(tempf) );
//Particle.publish(webhookTemp, TempZone1, 60, PRIVATE) ;
if (( tempf <= LowAlarmTemp) && LowAlarmSent == 0){
LowAlarmSent = 1;
if ( tempf >= LowAlarmSentClearTemp && LowAlarmSent == 1){
sprintf(TempZone1, "Temperature is normal Temp: %d F", int(tempf) );
LowAlarmSent = 0;
else { Serial.print("Temp below Floor Value");}
else {
Serial.print("Counter ");
Serial.println(loop_counter);
