Hi friends,
I am attempting to use the OneWire lib, and Spark-Dallas-temperature lib from the browser platform to get the DS18B20 water proof temperature sensor to work. The thing is i have it working in a different script than i am working on now, but when i try and copy it over verbatim i get the following error message;
lib/spark-dallas-temperature/src/spark-dallas-temperature.h:27:36: fatal error: ../OneWire/OneWire.h: No such file or directory
#include "../OneWire/OneWire.h"
I vaguely remember having a similar issue when i got the sensor working initially but cannot remember how i resolved it. Here is the code i am trying to get to compile. Thanks in advace
#include <spark-dallas-temperature.h>
#include <OneWire/OneWire.h>
#include "blynk.h"
//Relay Stuff
//WHICH IS WHAT??
#define RELAY_OFF 1
#define RELAY_ON 0
//Declare Relay pins
#define pumpRelay D0
#define nutrientRelay D1
#define waterInRelay D2
#define floodWaterInRelay D3
#define floodBasinRelay D4
#define floodBasinDrainRelay D5
#define heaterRelay D6
#define ONE_WIRE_BUS D7
#define TEMPERATURE_PRECISION 9
int waterTempF = -1;
double InTempC = -1;
//Sensors
//Water Temperature
OneWire oneWire(ONE_WIRE_BUS);
DallasTemperature sensors(&oneWire);
DeviceAddress inWaterThermometer = { 0x28, 0xB6, 0x78, 0x5E, 0x07, 0x0, 0x0, 0x4F };
void update18B20Temp(DeviceAddress deviceAddress, double &tempC);
//Blynk
char auth[] = "omitted";
Blynk.begin(auth);
//water temperature
sensors.begin();
sensors.setResolution(inWaterThermometer, TEMPERATURE_PRECISION);
// Particle.variable("WaterTemp",waterTempF);
//Relays
pinMode(pumpRelay, OUTPUT);
pinMode(nutrientRelay, OUTPUT);
pinMode(waterInRelay, OUTPUT);
pinMode(floodWaterInRelay, OUTPUT);
pinMode(floodBasinRelay, OUTPUT);
pinMode(floodBasinDrainRelay, OUTPUT);
pinMode(heaterRelay, OUTPUT);
digitalWrite(pumpRelay, RELAY_OFF);
digitalWrite(nutrientRelay, RELAY_OFF);
digitalWrite(waterInRelay, RELAY_OFF);
digitalWrite(floodWaterInRelay, RELAY_OFF);
digitalWrite(floodBasinRelay, RELAY_OFF);
digitalWrite(floodBasinDrainRelay, RELAY_OFF);
digitalWrite(heaterRelay, RELAY_OFF);
Blynk.run();
// digitalWrite(pumpRelay, RELAY_OFF);
// digitalWrite(nutrientRelay, RELAY_OFF);
// digitalWrite(waterInRelay, RELAY_OFF);
// digitalWrite(floodWaterInRelay, RELAY_OFF);
// delay(500);
// digitalWrite(pumpRelay, RELAY_ON);
// delay(500);
// digitalWrite(nutrientRelay, RELAY_ON);
// delay(500);
// digitalWrite(waterInRelay, RELAY_ON);
//delay(500);
// digitalWrite(floodWaterInRelay, RELAY_ON);
sensors.requestTemperatures();
update18B20Temp(inWaterThermometer, InTempC);
waterTempF = (InTempC * 9)/5 + 32;
//delay(1000);
tempC = sensors.getTempC(deviceAddress);
