Network error. Check your internet connection and try again
I tried to install particle on raspberry pi 3 but it return error about internet connection while my internet connection is working fine.
pi@raspberrypi:~ $ bash <( curl -sL https://particle.io/install-pi )
Installing the Particle Agent
Downloading packages
###########################################################################        ##########                                                            ##########                                                            #####################                                                 ################################                                      #################################################                     ############################################################################################################################################## 100.0%
Installing packages
Reading package lists... Done
Building dependency tree
Reading state information... Done
libssl-dev is already the newest version.
0 upgraded, 0 newly installed, 0 to remove and 32 not upgraded.
(Reading database ... 138834 files and directories currently installed.)
Preparing to unpack .../particle-agent_0.2.4-1_all.deb ...
Unpacking particle-agent (0.2.4-1) over (0.2.4-1) ...
Preparing to unpack .../ruby-unicode-display-width_1.1.1-1_all.deb ...
Unpacking ruby-unicode-display-width (1.1.1-1) over (1.1.1-1) ...
Preparing to unpack .../ruby-whirly_0.2.3-1_all.deb ...
Unpacking ruby-whirly (0.2.3-1) over (0.2.3-1) ...
Preparing to unpack .../ruby-particlerb_1.3.1-1_all.deb ...
Unpacking ruby-particlerb (1.3.1-1) over (1.3.1-1) ...
Setting up ruby-unicode-display-width (1.1.1-1) ...
Setting up ruby-whirly (0.2.3-1) ...
Setting up ruby-particlerb (1.3.1-1) ...
Setting up particle-agent (0.2.4-1) ...
Processing triggers for systemd (215-17+deb8u6) ...
Running sudo particle-agent setup
Let's connect your Raspberry Pi to the Particle Cloud!
You are already logged in as shaolinkhoa@gmail.com.
Do you want to stay logged in as this user? |yes| no
Email address: shaolinkhoa@gmail.com
Password:
⠹  Logging in
Would you mind helping ?
thank you and regards,
Khoa
Try sudo apt update && sudo apt upgrade and then try installing again.
Same issue but this didn’t work for me, still getting the Network error.
