$ bash <( curl -sL https://particle.io/install-pi )
Installing the Particle Agent
Downloading packages
######################################################################## 100,0%
Installing packages
Password: *[my password]*
sudo: apt-get: command not found
sudo: dpkg: command not found
/dev/fd/63: line 29: read: -N: invalid option
read: usage: read [-ers] [-u fd] [-t timeout] [-p prompt] [-a array] [-n nchars] [-d delim] [name ...]
Running sudo particle-agent setup
sudo: particle-agent: command not found
Are you running Raspbian?
https://docs.particle.io/guide/getting-started/start/raspberry-pi/#download-and-install-raspbian
Raspbian is not a good idea. It is much better buildroot.
If you know better, then what’s the actual question, since there wasn’t one in your original post, nor was there info on what setup you’re using, nor was there…
Long story short: don’t just dump an error, expect us to figure out what’s going on, and lecture us when despite that we make an effort to help.
