Hi everyone…
i follow this site " https://docs.particle.io/guide/getting-started/start/raspberry-pi/#particle-pi-beta " . and i use the QUICK INSTALL. but when i write : bash <( curl -sL https://particle.io/install-pi ) on my pi (version 3 ) nothing happens. next i use this code : sudo apt-get -f install bash <( curl -sL https://particle.io/install-pi ) .
then i get an error: dev/fd packget not found .
Are you running Raspbian?
yes
Try this:
sudo apt-get update
dont work
You might want to paste the error message cos “dont work” doesn’t give us any information to help
and when i write sudo apt-get -f install bash <(…) . its give an error : "dev/df package not found "
Hmm…
Try: which bash
SLOVED
i remove SD card and have new rasbian so bash command begin work
Thank you for your time
I am having exactly the same issue as described above,
I have already run the following commands,
sudo apt-get update
sudo apt-get upgrade
sudo rpi update
sudo apt-get dist-upgrade
which bash
sudo apt-get -f install <(…)
I can’t quite figure out exactly what anasManour did when he removed the SD card and now has a newer version of Raspbian.
any ideas?
OK, Solved, for anyone else who may be having the same issue,
I formatted the SD card and installed the raspbian stretch image which you can download from,
See the link to the installation guide on the same page,
Cheers
