I currently have a Particle Electron that is connected to a limit switch, that publishes data to the cloud real-time. Along with the existing setup, I would like to also publish anemometer data to the cloud.
Experience with debouncing circuity would be helpful.
I used this anemometer for my first weather station. A couple of points I learned:
It requires a minimum of 7VDC. I had to add a boost converter. Not a big deal but something you have to consider.
It is analog, so you don’t have to worry about debounce.
Data screams out of this device at an incredible rate (especially as the wind increases). If you’re using an Electron you might find your data charges excessive. Are you planning on some kind of average?
The device is heavy and you don’t get wind direction and/or rain.
I eventually moved to this setup and it’s so much easier:
