Interrupts and cloud connection
Hi guys :slight_smile:
I want to use a Davis 6410 wind sensor. There is a sample code for arduino:
I have adjusted the code that I can use it with my Photon:
#include <math.h>
#define WindSensorPin (2) // The pin location of the anemometer sensor
volatile unsigned long Rotations; // cup rotation counter used in interrupt routine
volatile unsigned long ContactBounceTime; // Timer to avoid contact bounce in interrupt routine
float WindSpeed; // speed miles per hour
pinMode(WindSensorPin, INPUT);
attachInterrupt(digitalPinToInterrupt(WindSensorPin), isr_rotation, FALLING);
Serial.println("Davis Wind Speed Test");
Serial.println("Rotations\tMPH");
Rotations = 0; // Set Rotations count to 0 ready for calculations
attachInterrupt(WindSensorPin, isr_rotation, FALLING);
delay(3000);
detachInterrupt(WindSensorPin);
// convert to mp/h using the formula V=P(2.25/T)
// V = P(2.25/3) = P * 0.75
WindSpeed = Rotations * 0.75;
Serial.print(Rotations); Serial.print("\t\t");
Serial.println(WindSpeed);
// This is the function that the interrupt calls to increment the rotation count
void isr_rotation () {
if ((millis() - ContactBounceTime) > 15 ) { // debounce the switch contact.
Rotations++;
ContactBounceTime = millis();
But when I use this code I have problems uploading a new code OTA. I think the problem are is the interrupt function. How I can adjust my code that I can upload my new code OTA still using the interrupt function?
Best regards
@electronweather, you may want to try this code instead of delay(3000). It allows the DeviceOS to process Cloud stuff during the delay.
for(uint32_t ms = millis(); millis() - ms < 3000L; Particle.process()); // Different version of delay(3000)
Also, use the correct Particle definition for the pin you want to use, in this case D2 I assume. The first attachInterrupt() function is not needed since, instead of using interrutps() and noInterrupts() you use attachInterrupt() and detachInterrupt(), which is a wise substitute. With these changes, you code would look like this:
#include <math.h>
#define WindSensorPin (D2)	// The pin location of the anemometer sensor
		Rotations++;
Thank you! :slight_smile:
But isnโ€™t it necessary to reset โ€œmsโ€ each loop?
@electronweather read the for loop! It gets reset there.
Ah now I can see it :slight_smile:
Is it necessary to call Particle.process()); if SYSTEM_THREAD(ENABLED); ?
Nope, you won't need to do that anymore - not even in SYSTEM_MODE(MANUAL)
So I dont have to use Particle.process());?
