[Resolved]- Particle can't read MPL3115A2 and Anemometer at same time
I’m working on a weather station, but every time I have the MPL3115A2 powered, my anemometer won’t output a value. Here’s the code:
#include "spark-dallas-temperature/spark-dallas-temperature.h"
#include "OneWire/OneWire.h"
#include "SparkFun_Photon_Weather_Shield_Library/SparkFun_Photon_Weather_Shield_Library.h"
  SparkFun_Photon_Weather_Basic_Soil_Meters.ino
  SparkFun Photon Weather Shield basic example with soil moisture and temp
  and weather meter readings including wind speed, wind direction and rain.
  Joel Bartlett @ SparkFun Electronics
  Original Creation Date: May 18, 2015
  Based on the Wimp Weather Station sketch by: Nathan Seidle
  https://github.com/sparkfun/Wimp_Weather_Station
  This sketch prints the temperature, humidity, barometric pressure, altitude,
  soil moisture, and soil temperature to the Seril port. This sketch also
  incorporates the Weather Meters avaialbe from SparkFun (SEN-08942), which allow
  you to measure Wind Speed, Wind Direction, and Rainfall. Upload this sketch
  after attaching a soil moisture and or soil temperature sensor and Wetaher
  Meters to test your connections.
  Hardware Connections:
	This sketch was written specifically for the Photon Weather Shield,
	which connects the HTU21D and MPL3115A2 to the I2C bus by default.
  If you have an HTU21D and/or an MPL3115A2 breakout,	use the following
  hardware setup:
      HTU21D ------------- Photon
      (-) ------------------- GND
      (+) ------------------- 3.3V (VCC)
       CL ------------------- D1/SCL
       DA ------------------- D0/SDA
    MPL3115A2 ------------- Photon
      GND ------------------- GND
      VCC ------------------- 3.3V (VCC)
      SCL ------------------ D1/SCL
      SDA ------------------ D0/SDA
    Soil Moisture Sensor ----- Photon
        VCC ------------------- D5
        SIG ------------------- A1
    DS18B20 Temp Sensor ------ Photon
        VCC (Red) ------------- 3.3V (VCC)
        GND (Black) ----------- GND
        SIG (White) ----------- D4
  Development environment specifics:
  	IDE: Particle Dev
  	Hardware Platform: Particle Photon
                       Particle Core
  This code is beerware; if you see me (or any other SparkFun
  employee) at the local, and you've found our code helpful,
  please buy us a round!
  Distributed as-is; no warranty is given.
int WDIR = A0;
int RAIN = D2;
int WSPEED = D3;
//OneWire and DallasTemperature libraries are needed for DS18B20 Temp sensor
long lastSecond; //The millis counter to see when a second rolls by
byte seconds; //When it hits 60, increase the current minute
byte seconds_2m; //Keeps track of the "wind speed/dir avg" over last 2 minutes array of data
byte minutes; //Keeps track of where we are in various arrays of data
byte minutes_10m;
byte windspdavg[120]; //120 bytes to keep track of 2 minute average
int winddiravg[120]; //120 ints to keep track of 2 minute average
float windgust_10m[10]; //10 floats to keep track of 10 minute max
int windgustdirection_10m[10]; //10 ints to keep track of 10 minute max
volatile float rainHour[60]; //60 floating numbers to keep track of 60 minutes of rain
//These are all the weather values that wunderground expects:
int winddir = 0; // [0-360 instantaneous wind direction]
float windspeedmph = 0; // [mph instantaneous wind speed]
float windgustmph = 0; // [mph current wind gust, using software specific time period]
int windgustdir = 0; // [0-360 using software specific time period]
float windspdmph_avg2m = 0; // [mph 2 minute average wind speed mph]
int winddir_avg2m = 0; // [0-360 2 minute average wind direction]
float windgustmph_10m = 0; // [mph past 10 minutes wind gust mph ]
int windgustdir_10m = 0; // [0-360 past 10 minutes wind gust direction]
float rainin = 0; // [rain inches over the past hour)] -- the accumulated rainfall in the past 60 min
long lastWindCheck = 0;
volatile float dailyrainin = 0; // [rain inches so far today in local time]
//float humidity = 0;
//float tempf = 0;
//float tempC = 0;//original temperature in C from DS18B20
//float soiltempf = 0;//converted temperature in F from DS18B20
float pascals = 0;
float altm = 0;
float baroTemp = 0;
//int soilMoisture = 0;
int count = 0;
volatile long lastWindIRQ = 0;
volatile byte windClicks = 0;
volatile unsigned long raintime, rainlast, raininterval, rain;
Weather sensor;
void rainIRQ()
// Count rain gauge bucket tips as they occur
// Activated by the magnet and reed switch in the rain gauge, attached to input D2
  raintime = millis(); // grab current time
  raininterval = raintime - rainlast; // calculate interval between this and last event
    if (raininterval > 10) // ignore switch-bounce glitches less than 10mS after initial edge
    dailyrainin += 0.011; //Each dump is 0.011" of water
    rainHour[minutes] += 0.011; //Increase this minute's amount of rain
    rainlast = raintime; // set up for next event
void wspeedIRQ()
// Activated by the magnet in the anemometer (2 ticks per rotation), attached to input D3
  if (millis() - lastWindIRQ > 10) // Ignore switch-bounce glitches less than 10ms (142MPH max reading) after the reed switch closes
    lastWindIRQ = millis(); //Grab the current time
    windClicks++; //There is 1.492MPH for each click per second.
//Wunderground Vars
//char SERVER[] = "rtupdate.wunderground.com"; //Rapidfire update server - for multiple sends per minute
char SERVER [] = "weatherstation.wunderground.com"; //Standard server - for sends once per minute or less
char WEBPAGE [] = "GET /weatherstation/updateweatherstation.php?";
//Station Identification
char ID [] = "KMNLUVER6"; //Your station ID here
char PASSWORD [] = "iyymypeh"; //your Weather Underground password here
TCPClient client;
    pinMode(WSPEED, INPUT_PULLUP); // input from wind meters windspeed sensor
    pinMode(RAIN, INPUT_PULLUP); // input from wind meters rain gauge sensor
    Serial.begin(9600);   // open serial over USB
    // Make sure your Serial Terminal app is closed before powering your device
    // Now open your Serial Terminal, and hit any key to continue!
    Serial.println("Press any key to begin");
    //This line pauses the Serial port until a key is pressed
    while(!Serial.available()) Particle.process();
    //Initialize the I2C sensors and ping them
    sensor.begin();
    /*You can only receive acurate barrometric readings or acurate altitiude
    readings at a given time, not both at the same time. The following two lines
    tell the sensor what mode to use. You could easily write a function that
    takes a reading in one made and then switches to the other mode to grab that
    reading, resulting in data that contains both acurate altitude and barrometric
    readings. For this example, we will only be using the barometer mode. Be sure
    to only uncomment one line at a time. */
    sensor.setModeBarometer();//Set to Barometer Mode
    //baro.setModeAltimeter();//Set to altimeter Mode
    //These are additional MPL3115A2 functions the MUST be called for the sensor to work.
    sensor.setOversampleRate(7); // Set Oversample rate
    //Call with a rate from 0 to 7. See page 33 for table of ratios.
    //Sets the over sample rate. Datasheet calls for 128 but you can set it
    //from 1 to 128 samples. The higher the oversample rate the greater
    //the time between data samples.
    sensor.enableEventFlags(); //Necessary register calls to enble temp, baro ansd alt
    seconds = 0;
    lastSecond = millis();
    // attach external interrupt pins to IRQ functions
    attachInterrupt(RAIN, rainIRQ, FALLING);
    attachInterrupt(WSPEED, wspeedIRQ, FALLING);
    // turn on interrupts
    interrupts();
  //Keep track of which minute it is
  if(millis() - lastSecond >= 1000)
    lastSecond += 1000;
    //Take a speed and direction reading every second for 2 minute average
    if(++seconds_2m > 119) seconds_2m = 0;
    //Calc the wind speed and direction every second for 120 second to get 2 minute average
    float currentSpeed = get_wind_speed();
    //float currentSpeed = random(5); //For testing
    int currentDirection = get_wind_direction();
    windspdavg[seconds_2m] = (int)currentSpeed;
    winddiravg[seconds_2m] = currentDirection;
    //if(seconds_2m % 10 == 0) displayArrays(); //For testing
    //Check to see if this is a gust for the minute
    if(currentSpeed > windgust_10m[minutes_10m])
      windgust_10m[minutes_10m] = currentSpeed;
      windgustdirection_10m[minutes_10m] = currentDirection;
    //Check to see if this is a gust for the day
    if(currentSpeed > windgustmph)
      windgustmph = currentSpeed;
      windgustdir = currentDirection;
    if(++seconds > 59)
      seconds = 0;
      if(++minutes > 59) minutes = 0;
      if(++minutes_10m > 9) minutes_10m = 0;
      rainHour[minutes] = 0; //Zero out this minute's rainfall amount
      windgust_10m[minutes_10m] = 0; //Zero out this minute's gust
    //Get readings from all sensors
    getWeather();
    //Rather than use a delay, keeping track of a counter allows the photon to
    // still take readings and do work in between printing out data.
    count++;
    //alter this number to change the amount of time between each reading
    if(count == 5)
       printInfo();
       //Print to console
    //Send Data to Weather Underground
    sendToWU();
       count = 0;
void printInfo()
  //This function prints the weather data out to the default Serial Port
      Serial.print("Wind_Dir:");
      switch (WDIR)
        case 0:
          Serial.print("North");
          break;
        case 1:
          Serial.print("NE");
          break;
        case 2:
          Serial.print("East");
          break;
        case 3:
          Serial.print("SE");
          break;
        case 4:
          Serial.print("South");
          break;
        case 5:
          Serial.print("SW");
          break;
        case 6:
          Serial.print("West");
          break;
        case 7:
          Serial.print("NW");
          break;
        default:
          Serial.print("No Wind");
          // if nothing else matches, do the
          // default (which is optional)
      Serial.print(" Wind_Speed:");
      Serial.print(windspeedmph, 1);
      Serial.print("mph, ");
      Serial.print("Rain:");
      Serial.print(rainin, 2);
      Serial.print("in., ");
      //Serial.print("Temp:");
      //Serial.print(tempF);
      //Serial.print("F, ");
     // Serial.print("Humidity:");
      //Serial.print(humidity);
     // Serial.print("%, ");
      Serial.print("Baro_Temp:");
      Serial.print(baroTemp);
      Serial.print("Pressure:");
      Serial.print(pascals/100);
      Serial.print("hPa, ");
      //The MPL3115A2 outputs the pressure in Pascals. However, most weather stations
      //report pressure in hectopascals or millibars. Divide by 100 to get a reading
      //more closely resembling what online weather reports may say in hPa or mb.
      //Another common unit for pressure is Inches of Mercury (in.Hg). To convert
      //from mb to in.Hg, use the following formula. P(inHg) = 0.0295300 * P(mb)
      //More info on conversion can be found here:
      //www.srh.noaa.gov/images/epz/wxcalc/pressureConversion.pdf
      //If in altitude mode, print with these lines
      //Serial.print("Altitude:");
      //Serial.print(altf);
      //Serial.println("ft.");
     // Serial.print("Soil_Temp:");
      //Serial.print(soiltempf);
      //Serial.print("Soil_Mositure:");
      //Serial.println(soilMoisture);//Mositure Content is expressed as an analog
      //value, which can range from 0 (completely dry) to the value of the
      //materials' porosity at saturation. The sensor tends to max out between
      //3000 and 3500.
void sendToWU()
Serial.println("connecting...");
if (client.connect(SERVER, 80)) {
Serial.println("Connected");
client.print(WEBPAGE);
client.print("ID=");
client.print(ID);
client.print("&PASSWORD=");
client.print(PASSWORD);
client.print("&dateutc=now"); //can use 'now' instead of time if sending in real time
client.print("&tempf=");
client.print(baroTemp);
//client.print("&dewptf=");
//client.print(dewptF);
//client.print("&humidity=");
//client.print(humidity);
client.print("&baromin=");
client.print(pascals);
client.print("&winddir=");
client.print(winddir);
client.print("&windspeedmph=");
client.print(windspeedmph);
client.print("&rainin=");
client.print(rainin);
client.print("&dailyrainin=");
client.print(dailyrainin);
client.print("&windgustmph=");
client.print(windgustmph);
client.print("&wwindgustdir=");
client.print(windgustdir);
client.print("&windspdmph_avg2m=");
client.print(windspdmph_avg2m);
client.print("&winddir_avg2m=");
client.print(winddir_avg2m);
client.print("&windgustmph_10m=");
client.print(windgustmph_10m);
client.print("&windgustdir_10m=");
client.print(windgustdir_10m);
client.print("&action=updateraw"); //Standard update rate - for sending once a minute or less
//client.print("&softwaretype=Particle-Photon&action=updateraw&realtime=1&rtfreq=5"); //Rapid Fire update rate - for sending multiple times per minute, specify frequency in seconds
client.println();
Serial.println("Upload complete");
delay(300); //Without the delay it goes to sleep too fast and the send is unreliable
}else{
Serial.println(F("Connection failed"));
return;
int get_wind_direction()
  unsigned int adc;
  adc = analogRead(WDIR); // get the current reading from the sensor
  // The following table is ADC readings for the wind direction sensor output, sorted from low to high.
  // Each threshold is the midpoint between adjacent headings. The output is degrees for that ADC reading.
  // Note that these are not in compass degree order! See Weather Meters datasheet for more information.
  //Wind Vains may vary in the values they return. To get exact wind direction,
  //it is recomended that you AnalogRead the Wind Vain to make sure the values
  //your wind vain output fall within the values listed below.
  if(adc > 2270 && adc < 2290) return (0);//North
  if(adc > 3220 && adc < 3299) return (1);//NE
  if(adc > 3890 && adc < 3999) return (2);//East
  if(adc > 3780 && adc < 3850) return (3);//SE
  if(adc > 3570 && adc < 3650) return (4);//South
  if(adc > 2790 && adc < 2850) return (5);//SW
  if(adc > 1580 && adc < 1610) return (6);//West
  if(adc > 1930 && adc < 1950) return (7);//NW
  return (-1); // error, disconnected?
//Returns the instataneous wind speed
float get_wind_speed()
  float deltaTime = millis() - lastWindCheck; //750ms
  deltaTime /= 1000.0; //Covert to seconds
  float windspeedmph = (float)windClicks / deltaTime; //3 / 0.750s = 4
  windClicks = 0; //Reset and start watching for new wind
  lastWindCheck = millis();
  windspeedmph *= 1.492; //4 * 1.492 = 5.968MPH
   Serial.println();
   Serial.print("Windspeed:");
   Serial.println(windspeedmph);
  return(windspeedmph);
void getWeather()
    // Measure Relative Humidity from the HTU21D or Si7021
   // humidity = sensor.getRH();
    // Measure Temperature from the HTU21D or Si7021
    //tempF = sensor.getTemperatureF();
    // Temperature is measured every time RH is requested.
    // It is faster, therefore, to read it from previous RH
    // measurement with getTemp() instead with readTemp()
    //Measure the Barometer temperature in F from the MPL3115A2
    baroTemp = sensor.readBaroTempF();
    //Measure Pressure from the MPL3115A2
    pascals = sensor.readPressure();
    //If in altitude mode, you can get a reading in feet  with this line:
    //float altf = sensor.readAltitudeFt();
   // getSoilTemp();//Read the DS18B20 waterproof temp sensor
   // getSoilMositure();//Read the soil moisture sensor
    //Calc winddir
    winddir = get_wind_direction();
    //Calc windspeed
    windspeedmph = get_wind_speed();
    //Calc windgustmph
    //Calc windgustdir
    //Report the largest windgust today
    windgustmph = 0;
    windgustdir = 0;
    //Calc windspdmph_avg2m
    float temp = 0;
    for(int i = 0 ; i < 120 ; i++)
      temp += windspdavg[i];
    temp /= 120.0;
    windspdmph_avg2m = temp;
    //Calc winddir_avg2m
    temp = 0; //Can't use winddir_avg2m because it's an int
      temp += winddiravg[i];
    temp /= 120;
    winddir_avg2m = temp;
    //Calc windgustmph_10m
    //Calc windgustdir_10m
    //Find the largest windgust in the last 10 minutes
    //Step through the 10 minutes
    for(int i = 0; i < 10 ; i++)
      if(windgust_10m[i] > windgustmph_10m)
        windgustmph_10m = windgust_10m[i];
        windgustdir_10m = windgustdirection_10m[i];
    //Total rainfall for the day is calculated within the interrupt
    //Calculate amount of rainfall for the last 60 minutes
    rainin = 0;
    for(int i = 0 ; i < 60 ; i++)
      rainin += rainHour[i];
I think it is a software problem because I had the particle print windspeedmph every time getwindspeed is run and it still outputs a reading, but reportInfo always reads at zero:
MPL3115A2 Found
No Temp/Humidity Device Detected
Windspeed:0.00
Windspeed:0.00
Windspeed:0.00
Windspeed:0.00
Windspeed:0.00
Windspeed:0.00
Windspeed:0.00
Windspeed:0.00
Windspeed:0.00
Windspeed:0.00
Wind_Dir:No Wind Wind_Speed:0.0mph, Rain:0.00in., Baro_Temp:67.55F, Pressure:961.09hPa, connecting...
Connected
Upload complete
Windspeed:10.50
Windspeed:0.00
Windspeed:10.50
Windspeed:0.00
Windspeed:10.50
Windspeed:0.00
Windspeed:13.50
Windspeed:0.00
Windspeed:9.00
Windspeed:0.00
Wind_Dir:No Wind Wind_Speed:0.0mph, Rain:0.00in., Baro_Temp:67.55F, Pressure:961.04hPa, connecting...
Connected
Upload complete
Windspeed:7.50
Windspeed:0.00
Windspeed:4.50
Windspeed:0.00
Windspeed:10.50
Windspeed:0.00
Windspeed:10.50
Windspeed:0.00
Windspeed:3.00
Windspeed:298.40
Wind_Dir:No Wind Wind_Speed:298.4mph, Rain:0.00in., Baro_Temp:67.55F, Pressure:960.98hPa, connecting...
Connected
Upload complete
Windspeed:9.00
Windspeed:0.00
Windspeed:4.50
Windspeed:0.00
Windspeed:16.49
Windspeed:0.00
Windspeed:10.50
Windspeed:0.00
Windspeed:7.50
Windspeed:0.00
Wind_Dir:No Wind Wind_Speed:0.0mph, Rain:0.00in., Baro_Temp:67.55F, Pressure:960.99hPa, connecting...
Connected
Upload complete
Windspeed:6.00
Windspeed:0.00
Windspeed:6.00
Windspeed:0.00
Windspeed:3.00
Windspeed:0.00
Windspeed:3.00
Windspeed:0.00
Windspeed:3.00
Windspeed:0.00
Wind_Dir:No Wind Wind_Speed:0.0mph, Rain:0.00in., Baro_Temp:67.55F, Pressure:960.98hPa, connecting...
Connected
Upload complete
Windspeed:3.00
Windspeed:0.00
This is what it looks like when the MPL is unpowered:
No Devices Detected
Windspeed:0.00
Windspeed:0.00
Windspeed:0.00
Windspeed:0.95
Windspeed:0.00
Windspeed:13.79
Windspeed:0.00
Windspeed:10.96
Windspeed:0.00
Windspeed:12.63
Wind_Dir:No Wind Wind_Speed:12.6mph, Rain:0.00in., Baro_Temp:-1766.20F, Pressure:-9.99hPa, connecting...
Connected
Upload complete
Windspeed:12.00
Windspeed:6.43
Windspeed:0.00
Windspeed:7.75
Windspeed:0.00
Windspeed:6.81
Windspeed:0.00
Windspeed:3.32
Windspeed:0.00
Windspeed:6.90
Wind_Dir:No Wind Wind_Speed:6.9mph, Rain:0.00in., Baro_Temp:-1766.20F, Pressure:-9.99hPa, connecting...
Connected
Upload complete
Windspeed:3.99
Windspeed:6.14
Windspeed:0.00
Windspeed:0.00
Windspeed:0.00
Windspeed:0.00
Windspeed:0.00
Windspeed:0.00
Windspeed:0.00
Windspeed:0.00
Wind_Dir:No Wind Wind_Speed:0.0mph, Rain:0.00in., Baro_Temp:-1766.20F, Pressure:-9.99hPa, connecting...
Connected
Upload complete
Hi Hans,
Can you possibly reduce your firmware to the smallest example that still reproduces the problem? As it stands the firmware you posted is simply too detailed and complicated to debug on the forums.
Happy Holidays!
I think I managed to figure it out. Thanks for the help!
Can you also post the solution you came up with, for the benefit of the community?
I would call it more of a workaround than a solution. I assume there was some conflict in the variable with wind gust calculations and averages. I don’t know much about coding and such, since learned it by doing this project, but this code is working to get temperature, pressure, speed, and direction.
int WSPEED = D3;
int WDIR = A0;
byte minutes_10m;
float pascals = 0;
float altm = 0;
float baroTemp = 0;
int dirr = 0;
int count = 0;
Weather sensor;
void wspeedIRQ()
TCPClient client;
    sensor.begin();
    seconds = 0;
    interrupts();
    lastSecond += 1000;
    getWeather();
    printInfo();
    sendToWU();
void printInfo()   {
   // his function prints the weather data out to the default Serial Port
      switch (dirr)
        case 0:
          break;
        case 1:
          Serial.print("NE");
          break;
        case 2:
          break;
        case 3:
          Serial.print("SE");
          break;
        case 4:
          break;
        case 5:
          Serial.print("SW");
          break;
        case 6:
          break;
        case 7:
          Serial.print("NW");
          break;
        default:
void sendToWU()
client.print(ID);
client.print(pascals * 0.0002953);
client.print(dirr);
//client.print("&rainin=");
//client.print(rainin);
//client.print("&dailyrainin=");
//client.print(dailyrainin);
//client.print("&windgustmph=");
//client.print(windgustmph);
//client.print("&wwindgustdir=");
//client.print(windgustdir);
//client.print("&windspdmph_avg2m=");
//client.print(windspdmph_avg2m);
//client.print("&winddir_avg2m=");
//client.print(winddir_avg2m);
//client.print("&windgustmph_10m=");
//client.print(windgustmph_10m);
//client.print("&windgustdir_10m=");
//client.print(windgustdir_10m);
client.println();
}else{
return;
  unsigned int adc;
  Serial.print(adc);
  if(adc > 2270 && adc < 2290) dirr = 0;//North
  if(adc > 3220 && adc < 3299) dirr = 1;//NE
  if(adc > 3890 && adc < 3999) dirr = 2;//East
  if(adc > 3780 && adc < 3850) dirr = 3;//SE
  if(adc > 3570 && adc < 3650) dirr = 4;//South
  if(adc > 2790 && adc < 2850) dirr = 5;//SW
  if(adc > 1580 && adc < 1610) dirr = 6;//West
  if(adc > 1930 && adc < 1950) dirr = 7;//NW
   Serial.println();
void getWeather()
By cutting out the “if” statements concerning wind gust and speed/ direction averages, while editing a few other variables, I managed to circumvent the problem. I’ll try to remember to post a github link to a full working code once I’m finished.
