Trouble Shooting Errors in Code
Hi there,
I am a very inexperienced programmer that is having a few errors come up from the attached code. I was hoping for some insight as to how to fix these.
I am using these weather meters:
A one wire temperature sensor to measure temperature and an accelerometer to measure wave weight.
I still have to include the MPU 6050 Accelerometer code, because of the issues I am having with the weather meters. Once those are fixed I will add the rest.
The temperature sensor is working well, with the Particle.Publish function and doing what I require it to do.
I am also looking for help to understand how to create a Particle.Publish line for the Wind Speed and Wind Direction, as I had a teacher help me with the first one, I am unsure how to create ones for these other variables.
The errors I am receiving are below the code.
Any help is greatly appreciated!!
CODE:
**// This #include statement was automatically added by the Particle IDE.**
**#include "OneWire/OneWire.h"**
**#include "SparkFun_Photon_Weather_Shield_Library/SparkFun_Photon_Weather_Shield_Library.h"**
**#include "ThingSpeak/ThingSpeak.h"**
**#include "SparkFun_Photon_Weather_Shield_Library.h"**
int WDIR = A0;
int WSPEED = D3;
int rainHour;
//Global Variables
long lastSecond; //The millis counter to see when a second rolls by
byte seconds; //When it hits 60, increase the current minute
byte seconds_2m; //Keeps track of the "wind speed/dir avg" over last 2 minutes array of data
byte minutes; //Keeps track of where we are in various arrays of data
byte minutes_10m; //Keeps track of where we are in wind gust/dir over last 10 minutes array of data
byte windspdavg[120]; //120 bytes to keep track of 2 minute average
int winddiravg[120]; //120 ints to keep track of 2 minute average
float windgust_10m[10]; //10 floats to keep track of 10 minute max
int windgustdirection_10m[10]; //10 ints to keep track of 10 minute max
//These are all the weather values that wunderground expects:
int winddir = 0; // [0-360 instantaneous wind direction]
float windspeedmph = 0; // [mph instantaneous wind speed]
float windgustmph = 0; // [mph current wind gust, using software specific time period]
int windgustdir = 0; // [0-360 using software specific time period]
float windspdmph_avg2m = 0; // [mph 2 minute average wind speed mph]
int winddir_avg2m = 0; // [0-360 2 minute average wind direction]
float windgustmph_10m = 0; // [mph past 10 minutes wind gust mph ]
int windgustdir_10m = 0; // [0-360 past 10 minutes wind gust direction]
long lastWindCheck = 0;
int avg[100];
int count = 0;
// volatiles are subject to modification by IRQs
volatile long lastWindIRQ = 0;
volatile byte windClicks = 0;
int now=0;  //used for timer
int lasttime=0;
// Comment this out for normal operation
//SYSTEM_MODE(SEMI_AUTOMATIC);  // skip connecting to the cloud for (Electron) testing
OneWire ds = OneWire(D4);  // 1-wire signal on pin D4
unsigned long lastUpdate = 0;
  // Set up 'power' pins, comment out if not used!
  pinMode(D3, OUTPUT);
  pinMode(D5, OUTPUT);
  digitalWrite(D3, LOW);
  digitalWrite(D5, HIGH);
  pinMode(WSPEED, INPUT_PULLUP); // input from wind meters windspeed sensor
    // attach external interrupt pins to IRQ functions
  attachInterrupt(WSPEED, wspeedIRQ, FALLING);
    // turn on interrupts
    interrupts();
// up to here, it is the same as the address acanner
// we need a few more variables for this example
void loop(void) {
  byte i;
  byte present = 0;
  byte type_s;
  byte data[12];
  byte addr[8];
  float celsius, fahrenheit;
  if ( !ds.search(addr)) {
    Serial.println("No more addresses.");
    Serial.println();
    ds.reset_search();
    delay(250);
    return;
  // The order is changed a bit in this example
  // first the returned address is printed
  Serial.print("ROM =");
  for( i = 0; i < 8; i++) {
    Serial.write(' ');
    Serial.print(addr[i], HEX);
  // second the CRC is checked, on fail,
  // print error and just return to try again
  if (OneWire::crc8(addr, 7) != addr[7]) {
      Serial.println("CRC is not valid!");
      return;
  Serial.println();
  ds.reset();               // first clear the 1-wire bus
  ds.select(addr);          // now select the device we just found
  // ds.write(0x44, 1);     // tell it to start a conversion, with parasite power on at the end
  ds.write(0x44, 0);        // or start conversion in powered mode (bus finishes low)
  delay(1000);     // maybe 750ms is enough, maybe not, wait 1 sec for conversion
    present = ds.reset();
  ds.select(addr);
  ds.write(0xB8,0);         // Recall Memory 0
  ds.write(0x00,0);         // Recall Memory 0
  // now read the scratch pad
  ds.select(addr);
  ds.write(0xBE,0);         // Read Scratchpad
  if (type_s == 2) {
    ds.write(0x00,0);       // The DS2438 needs a page# to read
  // transfer and print the values
  Serial.print("  Data = ");
  Serial.print(present, HEX);
  Serial.print(" ");
  for ( i = 0; i < 9; i++) {           // we need 9 bytes
    data[i] = ds.read();
    Serial.print(data[i], HEX);
    Serial.print(" ");
  Serial.print(" CRC=");
  Serial.print(OneWire::crc8(data, 8), HEX);
  Serial.println();
  // Convert the data to actual temperature
  // because the result is a 16 bit signed integer, it should
  // be stored to an "int16_t" type, which is always 16 bits
  // even when compiled on a 32 bit processor.
  int16_t raw = (data[1] << 8) | data[0];
  if (type_s == 2) raw = (data[2] << 8) | data[1];
  byte cfg = (data[4] & 0x60);
  switch (type_s) {
    case 1:
      raw = raw << 3; // 9 bit resolution default
      if (data[7] == 0x10) {
        // "count remain" gives full 12 bit resolution
        raw = (raw & 0xFFF0) + 12 - data[6];
      celsius = (float)raw * 0.0625;
      break;
    case 0:
      // at lower res, the low bits are undefined, so let's zero them
      if (cfg == 0x00) raw = raw & ~7;  // 9 bit resolution, 93.75 ms
      if (cfg == 0x20) raw = raw & ~3; // 10 bit res, 187.5 ms
      if (cfg == 0x40) raw = raw & ~1; // 11 bit res, 375 ms
      // default is 12 bit resolution, 750 ms conversion time
      break;
    case 2:
      data[1] = (data[1] >> 3) & 0x1f;
      if (data[2] > 127) {
        celsius = (float)data[2] - ((float)data[1] * .03125);
      }else{
        celsius = (float)data[2] + ((float)data[1] * .03125);
// Wind Speed and Direction Below
  //Keep track of which minute it is
  if(millis() - lastSecond >= 1000)
    lastSecond += 1000;
    //Take a speed and direction reading every second for 2 minute average
    if(++seconds_2m > 119) seconds_2m = 0;
    //Calc the wind speed and direction every second for 120 second to get 2 minute average
    float currentSpeed = get_wind_speed();
    //float currentSpeed = random(5); //For testing
    int currentDirection = get_wind_direction();
    windspdavg[seconds_2m] = (int)currentSpeed;
    avg[seconds_2m] = currentDirection;
    //if(seconds_2m % 10 == 0) displayArrays(); //For testing
    //Check to see if this is a gust for the minute
    if(currentSpeed > windgust_10m[minutes_10m])
      windgust_10m[minutes_10m] = currentSpeed;
      windgustdirection_10m[minutes_10m] = currentDirection;
    //Check to see if this is a gust for the day
    if(currentSpeed > windgustmph)
      windgustmph = currentSpeed;
      windgustdir = currentDirection;
    if(++seconds > 59)
      seconds = 0;
      if(++minutes > 59) minutes = 0;
      if(++minutes_10m > 9) minutes_10m = 0;
     // rainHour[minutes] = 0; //Zero out this minute's rainfall amount
      windgust_10m[minutes_10m] = 0; //Zero out this minute's gust
    //Calc winddir
    winddir = get_wind_direction();
    //Calc windspeed
    windspeedmph = get_wind_speed();
    //Calc windgustmph
    //Calc windgustdir
    //Report the largest windgust today
    windgustmph = 0;
    windgustdir = 0;
    //Calc windspdmph_avg2m
    float temp = 0;
    for(int i = 0 ; i < 120 ; i++)
      temp += windspdavg[i];
    temp /= 120.0;
    windspdmph_avg2m = temp;
    //Calc winddir_avg2m
    temp = 0; //Can't use winddir_avg2m because it's an int
      temp += winddiravg[i];
    temp /= 120;
    winddir_avg2m = temp;
    //Calc windgustmph_10m
    //Calc windgustdir_10m
    //Find the largest windgust in the last 10 minutes
    //Step through the 10 minutes
    for(int i = 0; i < 10 ; i++)
      if(windgust_10m[i] > windgustmph_10m)
        windgustmph_10m = windgust_10m[i];
        windgustdir_10m = windgustdirection_10m[i];
}//end of loop
void wspeedIRQ()
// Activated by the magnet in the anemometer (2 ticks per rotation), attached to input D3
  if (millis() - lastWindIRQ > 10) // Ignore switch-bounce glitches less than 10ms (142MPH max reading) after the reed switch closes
    lastWindIRQ = millis(); //Grab the current time
    windClicks++; //There is 1.492MPH for each click per second.
void printInfo()
  //This function prints the weather data out to the default Serial Port
      Serial.print("Wind_Dir:");
      switch (winddir)
        case 0:
          Serial.print("North");
          break;
        case 1:
          Serial.print("NE");
          break;
        case 2:
          Serial.print("East");
          break;
        case 3:
          Serial.print("SE");
          break;
        case 4:
          Serial.print("South");
          break;
        case 5:
          Serial.print("SW");
          break;
        case 6:
          Serial.print("West");
          break;
        case 7:
          Serial.print("NW");
          break;
        default:
          Serial.print("No Wind");
          // if nothing else matches, do the
          // default (which is optional)
      Serial.print(" Wind_Speed:");
      Serial.print(windspeedmph, 1);
      Serial.print("mph, ");
//Read the wind direction sensor, return heading in degrees
int get_wind_direction()
  unsigned int adc;
  adc = analogRead(WDIR); // get the current reading from the sensor
  // The following table is ADC readings for the wind direction sensor output, sorted from low to high.
  // Each threshold is the midpoint between adjacent headings. The output is degrees for that ADC reading.
  // Note that these are not in compass degree order! See Weather Meters datasheet for more information.
  //Wind Vains may vary in the values they return. To get exact wind direction,
  //it is recomended that you AnalogRead the Wind Vain to make sure the values
  //your wind vain output fall within the values listed below.
  if(adc > 2270 && adc < 2290) return (0);//North
  if(adc > 3220 && adc < 3299) return (1);//NE
  if(adc > 3890 && adc < 3999) return (2);//East
  if(adc > 3780 && adc < 3850) return (3);//SE
  if(adc > 3570 && adc < 3650) return (4);//South
  if(adc > 2790 && adc < 2850) return (5);//SW
  if(adc > 1580 && adc < 1610) return (6);//West
  if(adc > 1930 && adc < 1950) return (7);//NW
  return (-1); // error, disconnected?
//Returns the instataneous wind speed
float get_wind_speed()
  float deltaTime = millis() - lastWindCheck; //750ms
  deltaTime /= 1000.0; //Covert to seconds
  float windSpeed = (float)windClicks / deltaTime; //3 / 0.750s = 4
  windClicks = 0; //Reset and start watching for new wind
  lastWindCheck = millis();
  windSpeed *= 1.492; //4 * 1.492 = 5.968MPH
  /* Serial.println();
   Serial.print("Windspeed:");
   Serial.println(windSpeed);*/
  return(windSpeed);
now =millis();
if(now-lasttime>60000){
 lasttime=now;
  fahrenheit = celsius * 1.8 + 32.0;
  Serial.print("  Temperature = ");
  Serial.print(celsius);
  Particle.publish("Water_Temperature", String::format("%.1f:%.1f",celsius,fahrenheit));
  Serial.print(" Celsius, ");
  Serial.print(fahrenheit);
  Serial.println(" Fahrenheit");
ERRORS:
For the ‘now’ error, have a look over here and double check your data type.
https://www.arduino.cc/en/Reference/Millis
Actually I think you have a problem with your curly braces.
  return(windSpeed);
}  // <-- here the function ends
now =millis();  // <-- so this is not allowed at this position
 lasttime=now;
Usually after the end of your get_wind_speed() the compiler would expect the start of a new function declaration, which would start with a return type, so now should be a type but is a variable - hence the error.
This nicely shows how important proper indentation is - it’s not just for the good looks of the code, but also to see such errors at first glance :wink:
But @Moors7 has still a point. Don’t mix unsigned int millis() with (signed) int now (or int lasttime)! This would only give you grief.
