My dashboard is very simple with only two options: Devices and Logs. Devices appears to work and gives me basic information on my devices (ID, Type, Name - which I can change in dashboard, and Last Connection). Logs, however, does not appear to do anything for me. It is always blank. I’ve even tried to add a simple Particle.publish () command to one of my working programs, but nothing appears in the Logs. Is there a setup routine I need to initiate? Even if my Particle.publish doesn’t work shouldn’t I at least see a log entry when I flash a device? Any thoughts/advice you have would be most welcome! Thanks1
Hi a6pack,
No, no extra setup required. You should see the events published with the Particle.publish(“myEvent”) pop up in the dashboad logs.
A particle can only publish at a maximum rate of 1 event/ seconds, as described in the documentation :
NOTE: Currently, a device can publish at rate of about 1 event/sec, with bursts of up to 4 allowed in 1 second. Back to back burst of 4 messages will take 4 seconds to recover.
https://docs.particle.io/reference/firmware/photon/#particle-publish-
What browser are you using?
Have you tried others?
Have you altered some security options that might prevent SSE subscription?
I’m using Chrome on Windows and it works fine.
